turn on suggestions
ADSL & FTTC Router
- ADSL & FTTC Router
ADSL & FTTC Router
ADSL & FTTC Router
02-04-2013 6:22 PM
I'm currently migrating into PlusNet on ADSL2+ from Sky and have a new PlusNet router coming.
However I'm hoping BT will have FTTC'd my cabinet in a couple of weeks is it a problem to change to FTTC and get a new FTTC router when I've only had the ADSL one for a couple of weeks? Or will I be charged?
Re: ADSL & FTTC Router
02-04-2013 6:27 PM
You can use the same router for both, the difference between the FTTC/ADSL version is all in the firmware.
02-04-2013 6:29 PM
Oh ok just on the PN website it says the ADSL is technicolour and the FTTC is a net gear?
02-04-2013 6:30 PM
Not with the one you are provided unless the firmware is flashed
I may be completely wrong but I don't think having received an ADSL router with a 12 month tie in (and still within it) will have any affect on getting a new fibre router which is mandatory for a fibre instalation
To answer the bit above - The Netgear is no longer provided AFAIK
02-04-2013 6:34 PM
Ok so probably get the same router again but with different software lol
02-04-2013 8:10 PM
The TG582n FTTC router also has a USB port and LAN port 4 is used to connect to the FTTC modem provided by BT OR.
David
03-04-2013 4:53 AM
I heard this VMG1312-B Series router will support BT FTTC VDSL2 and one of the best for FTTC here: http://www.zyxel.com/uk/en/products_services/vmg1312_b_series.shtml?t=p&cx=20110503150743 and can purchase here: http://www.broadbandbuyer.co.uk/Shop/ShopDetail.asp?ProductID=15196&utm_source=google&utm_medium=sho...
