ADSL Speed
- ADSL Speed
ADSL Speed
18-10-2007 8:50 PM
Re: ADSL Speed
18-10-2007 9:08 PM
Could I possibly ask you to run a BT Speedtest at http://www.speedtester.bt.com ?
That will allow us to see what your IP Profile is. May also be worth reading the speed link in my signature
Re: ADSL Speed
18-10-2007 9:52 PM
Re: ADSL Speed
18-10-2007 10:14 PM
Re: ADSL Speed
18-10-2007 10:57 PM
Why do you always recommend the BT speedtester?
It is always difficult to connect to and often comes back with an error message or busy message.
What is wrong with the PN speedtester? Alternatively there are good ones at www.thinkbroadband.com and www.dslzone.co.uk
Re: ADSL Speed
18-10-2007 10:59 PM
other speedtesters can tell you you're only downloading at 60kb/s, but they can't tell you your profile has been restricted to 135k.
B.
Re: ADSL Speed
18-10-2007 11:02 PM
Often the profile and sync rates are the clue to why the speeds have changed.
Also BT require them before faults will be accepted.
The reliability of the speedtester is a major issue though but it has been like that ever since BT replaced the old (and also inconsitantly available) speedtester with the current one.
Re: ADSL Speed
19-10-2007 11:31 PM
Unfortuanely the speed has now dropped in the last couple of days to 3800 and below - varying between 1800 and 2800 on the speed tester (BT and their own) no matter what time of day .. be it 2 in the morning or 8 / 9 in the morning. I am being told it is contention and PN are not going to do anything about it depsite the being a business connection on Max Premium 20:1 contention.
My exchange isnt showing red .. and all the exchange checkers say the same .. there are no special notes at all.
It's a real problem that hits the business but seemingly no one can do anything.
Re: ADSL Speed
21-10-2007 11:36 PM
I have an 8Mb service (supposedly) that performs exactly like a 2Mb line. The line rate reported on the router is a very reasonable sounding 5695mbps.
http://dewin.net/bttest.jpg
is a picture I have submitted in a ticket, but was told "the line will settle down to a better speed" (not an exact quotation).
I think they've got it badly wrong. I believe the line is misconfigured. Am I right?
Re: ADSL Speed
22-10-2007 1:02 AM
Restarting the router once per day is recommended to nudge the BTw monitoring equipment to update your profile.
Note that the maximum IP profile achievable on an up-to-8Mbps line is 7150kbps (allowing for ATM protocol overheads) though the maximum achievable on a particular line depends on attenuation (which depends primarily on line length from the exchange and line condition).
Re: ADSL Speed
22-10-2007 8:22 AM
Moemoff,
Your product isn't actually a 20:1 contention product as BT scrapped this since the implementation of IPStream Max and IPStream Max Premium. IPStream Max Premium does offer a higher level of prioritisation, but is still affected by exchange contention. Please note that VP Congestion does not equal exchange contention, nor vice versa. If there are some heavy users at the exchange, they can highly contend the exchange without necessarily congest the Virtual Paths. (Hopefully I'm not talking out of my rear here, but that's my understanding).
If your speeds are fine outside main hours then we can raise this to BT, but their response is highly likely to be "This is likely to be caused by congestion on the internet" and we may not be able to supply any resolution as it is a restriction of the product.
Re: ADSL Speed
22-10-2007 8:26 AM
Is your router/modem syncing as high as it can?
Re: ADSL Speed
22-10-2007 8:29 AM
According to the information that we're receiving from BT, you are on a 5000Kbps profile, which is being mapped across our network. Have you tried rebooting your router recently? Because you are on your first 10 days on the IPStream Max product, this can be subject to change, however, looking at your line, those stats should suggest that you'll be able to hold a decent connection to the tune of 4-5Mbps.
Re: ADSL Speed
22-10-2007 9:03 AM
Quote from: artmo
Works for me anytime i try it.
Re: ADSL Speed
22-10-2007 12:41 PM
I'll hold on for a few days.
I've been rebooting a few times, and a test moments ago reconfirmed the 2000k IP Profile, even though my line rate has increased beyond 7k.
I'll keep watching
