ADSL Speed dropping
chrisn53
ADSL Speed dropping
Some tips please!
I've been at my current address for about 2 years and noticed the speed is gradually dropping. I used to have ~4meg then 3 and now 2.2 Sad
I've always used the same Draytek Vigor 2710 and use quality ADSL filters.
ADSL Status
Mode ADSL2+(G.992.5)
State SHOWTIME
Up Speed 971612
Down Speed    2268770
SNR Margin 11
Loop Att.  53
If I use the speed problem wizard it tells me to use the plusnet supplied router but I do not have one (old subscriber upgraded from diallup).
Checked wiring etc  and normally turning off the router for a period resets my profile but this time it's stuck.
help!
Chris
Plusnet Alumni (retired) LinnPlusnet
Re: ADSL Speed dropping
Hi there chrisn53,
I've placed the order to un-band your line as it was banded which restricted your speed. This should take effect within the next 10-15 minutes. Let us know if you don't see an increase in your speed.
chrisn53
wow thanks! It's now just under 4meg again.
A very happy customer!
_chris
