ADSL Question
- ADSL Question
ADSL Question
25-09-2013 1:39 PM
I know my broadband hasn't been active for a whole 24 hours yet - but it is working well... One thing I noticed though, is that the router is reporting the ADSL type as G.992.1 - I thought our exchange was 21CN enabled, and therefore ADSL2+ ? Is this just a TG582n quirk?
I doubt I'd get an increase in speed as I am showing a downstream attenuation of 41 dB and margin of 6.8 dB (current sync is about 6800Kbpbs)... I think I managed about 7500 Kbps on Sky - but not quibbling as it is better that no broadband - which is what we've had for the past month!
Andy
Re: ADSL Question
25-09-2013 2:37 PM
Put your telephone number in to http://www.dslchecker.bt.com/adsl/adslchecker.welcome
If it doesn't list WBC ADSL 2+ your exchange is still 20CN only.
The other possibility is that you've been put on ADSL1 on 21CN - but that would be strange given your speed.
Re: ADSL Question
25-09-2013 2:53 PM
Hi jelv,
Just checked it says that WBC ADSL 2+ is available (I had to use the postcode checker as my telephone no. is new)... I also checked the exchange at samknows...
Probably just on ADSL1...
Andy
Re: ADSL Question
25-09-2013 3:07 PM
Re: ADSL Question
25-09-2013 4:02 PM
Hi Adam,
No, that's fine - best left alone as it wouldn't be much better on 2+
Cheers,
Andy
Re: ADSL Question
25-09-2013 4:09 PM
Quote from: _Adam_Walker_ Hi there,
Yes, you seem to be on ADSL1 over 21CN. I don't see much point modifying the service to ADSL2+ given that your current speed profile is over the original estimate.
Adam
I disagree - the predicted speed on Kitz's utility for a 41 db attenuation is 6688 on ADSL1 and 8640 for ADSL2+
Has the upload speed been restricted to 448 as well - if so that should be uncapped.
Re: ADSL Question
25-09-2013 4:24 PM
Actually yes, good point the upload is at 448...
Is the change to ADSL2+ just a config update or does someone need to move wires - I am jittery about moving wires in the exchange...
If it is just a profile update can it be switched for me?
Ta,
Andy
Re: ADSL Question
25-09-2013 4:31 PM
Re: ADSL Question
25-09-2013 4:34 PM
Re: ADSL Question
25-09-2013 4:58 PM
We'll see what happens
Andy
Re: ADSL Question
26-09-2013 7:23 AM
Andy
