ADSL MAX and Metronet
GWGY
I am a metronet customer (PAYgo option 2) and am gettng a download speed averaging about 0.9Mbs. Have checked the ringwire and that is disconnected.
Am I on ADSL Max already?
If not, how can I upgrade to ADSL Max please?  My exchange is Millbrook Cornwall
Username geoffr433 if that helps.
Geoff
Mand
Re: ADSL MAX and Metronet
You're on a fixed 1000 product, so 0.9Mb is pretty good. Smiley
I can change you to Max if you like, it'll take about 24 hours.
I do need to tell you that if you have wiring issues or a long line you may get instability but the line check shows an estimated Max speed of 4Mb so I'd say it's worth a shot.
Gimme a nudge if you want me to place the order for you. Smiley
GWGY
Hi Mand
Thanks for the swift reply.
If the line becomes unstable can I go back?
Geoff
Sure, that shouldn't be a problem.
GWGY
HI Matt,
OK - please place the order for ADSL MAX for me. Understand it will take about 24 hrs to process.
Cheers
Geoff
Order placed and it is indeed due to complete tomorrow. Bear in mind the first 10 days may be a bit odd as the line settles in, if there's any problems following that period please let us know.
