ADSL MAX and Metronet
- ADSL MAX and Metronet
28-04-2010 10:53 AM
I am a metronet customer (PAYgo option 2) and am gettng a download speed averaging about 0.9Mbs. Have checked the ringwire and that is disconnected.
Am I on ADSL Max already?
If not, how can I upgrade to ADSL Max please? My exchange is Millbrook Cornwall
Username geoffr433 if that helps.
Geoff
Geoff
Message 1 of 6
(987 Views)
5 REPLIES 5
Re: ADSL MAX and Metronet
28-04-2010 10:58 AM
You're on a fixed 1000 product, so 0.9Mb is pretty good.
I can change you to Max if you like, it'll take about 24 hours.
I do need to tell you that if you have wiring issues or a long line you may get instability but the line check shows an estimated Max speed of 4Mb so I'd say it's worth a shot.
Gimme a nudge if you want me to place the order for you.
Message 2 of 6
(539 Views)
28-04-2010 1:11 PM
Hi Mand
Thanks for the swift reply.
If the line becomes unstable can I go back?
Geoff
Geoff
Message 3 of 6
(539 Views)
28-04-2010 2:07 PM
Sure, that shouldn't be a problem.
Message 4 of 6
(539 Views)
28-04-2010 2:13 PM
HI Matt,
OK - please place the order for ADSL MAX for me. Understand it will take about 24 hrs to process.
Cheers
Geoff
Cheers
Geoff
Message 5 of 6
(539 Views)
28-04-2010 2:58 PM
Order placed and it is indeed due to complete tomorrow. Bear in mind the first 10 days may be a bit odd as the line settles in, if there's any problems following that period please let us know.
Message 6 of 6
(539 Views)
