ADSL Filters
- ADSL Filters
Re: ADSL Filters
08-09-2008 9:44 PM
Re: ADSL Filters
09-09-2008 12:32 AM
The filtered faceplates just have microfilters built in. As long as you have a good quality stand alone microfilter there is no technical reason to replace it with the faceplate. Purely aesthetic.
Re: ADSL Filters
09-09-2008 7:24 AM
I measured the effect of the number of bits each ADSL channel could carry:
http://www.dougrice.plus.com/Erlangs/adsl_Appendix.htm#l21
A lot of people have found that interference picked up on the bell wire degraded the downstream speed. BT have introduced a simple to fit bell wire filter to fit to the master socket, and now appear to be fitting master sockets that filter off interference picked up by the bell wire.
See: http://www.dougrice.plus.com/Erlangs/adsl.htm#l5
I also brought some telephone extension wire where all four wires were loosely twisted if twisted at all. It is important to use twisted pairs to reduce the amount of interference picked up.
Doug
Re: ADSL Filters
09-09-2008 7:47 AM
Last evening over a one hour period with only my router connected my connection dropped 12 times with no activity!!
It than ran for 4 hours without dropping at all while in use.
Overnight I switched the router off and this morning it seems to be stable.
My basic question is, could this be caused by anything other than the filter?, Jack.
Re: ADSL Filters
09-09-2008 9:41 AM
Re: ADSL Filters
09-09-2008 9:43 AM
Try running a quiet line test when your connection drops and see if you're seeing a considerable amount of static on your line. If you are, report your fault to BT, without mentioning that you have a broadband service.
Re: ADSL Filters
09-09-2008 9:56 AM
At the moment I'm waiting for the post which should include some new filters from ADSL Nation when they arrive I will set one up with the phone connected and see what happens, Jack.
Re: ADSL Filters
09-09-2008 10:12 AM
Obviously something is happening on your line when you receive a call and the broadband gets knocked off. Do you hear any static on your line when that call is received, or is it perfectly clear?
Re: ADSL Filters
09-09-2008 10:24 AM
Post arrived, no filters off to Maplins to buy one, will let you know the results, Jack.
Re: ADSL Filters
09-09-2008 12:24 PM
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:04:56:26
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 4960 Kbps 448 Kbps
Noise Margin 15.2 dB 21.0 dB
Line Attenuation 15.5 dB 20.0 dB
Output Power 19.8 dBm 12.1 dBm
K (number of bytes in DMT frame) 156 15
R (number of check bytes in RS code word) 12 4
S (RS code word size in DMT frame) 1 4
D (interleaver depth) 32 8
Super Frames 1046257 1046255
Super Frame Errors 6 0
RS Words 71145528 17786335
RS Correctable Errors 860 0
RS Uncorrectable Errors 44 0
HEC Errors 3 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
These are my router stats, I will now replace the filter and reconnect the phone and see what happens, Jack.
Re: ADSL Filters
09-09-2008 12:47 PM
Checked Stats and already 3 drops, now I really am sure the filter is not the problem.
Don't know where to go from here James, any advice, Jack.
Latency Type Interleave Line Up Time 00:00:00:40
Line Coding Trellis On Line Up Count 3
Line Rate 3936 Kbps 256 Kbps
Noise Margin 14.6 dB 8.0 dB
Line Attenuation 39.0 dB 21.5 dB
Output Power 19.8 dBm 12.4 dBm
K (number of bytes in DMT frame) 124 9
R (number of check bytes in RS code word) 10 4
Super Frames 2351 2349
Super Frame Errors 0 0
RS Words 159934 39933
RS Correctable Errors 0 0
RS Uncorrectable Errors 0 0
HEC Errors 0 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
Have now disconnected the phone as sure this is the problem, Jack.
Re: ADSL Filters
09-09-2008 12:57 PM
I've just tried calling you, but the line kept ringing.
Can you try conencting your phone (via filter) and router directly into your BT Test socket and then try making an outbound call and call your line from your mobile. See if the line drops. If it doesn't, it's probably a probably with either your master socket itself or your internal wiring. If it does continue to drop, then it'll be a problem with the line.
Re: ADSL Filters
09-09-2008 1:30 PM
Re: ADSL Filters
09-09-2008 1:43 PM
If you're getting disconnections without the phone connected (and all other phone sockets have nothing connected), then you'll need to raise a fault with us.
You can do so by going to http://faults.plus.net
Thanks for trying as much as you have done so far
Re: ADSL Filters
09-09-2008 2:01 PM
