ADSL Broadband - Issues with speed
- ADSL Broadband - Issues with speed
on
03-05-2020
8:31 AM
- last edited on
03-05-2020
10:50 AM
by
Hello All,
I was recently given a hub one router by Plusnet because my previous router (2704n stopped working). I have noticed since the change that the speed of our internet is slower. Sometimes when we use the internet through the tv it freezes a lot now, and if we download an application onto the iPad it takes a long time for it to download. This never used to be a problem with our old router. I have spoken to a Plusnet technical person who tested the line and did something to try and make it faster but it has made no difference. Can anyone give me any help or suggestions as to what I can do now? Thanks in advance for any help you can give.
Kind Regards
Greg
Moderators Note: All caps title removed as per Forum rules
Re: ADSL BROADBAND - ISSUES WITH SPEED
03-05-2020 10:14 AM
Assuming that this is a wireless problem try splitting the 2.4 and 5 GHz bands, see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Re: ADSL Broadband - Issues with speed
03-05-2020 11:02 AM
Or use instructions below:
Navigate in a web browser to 192.168.1.254.
Click Advanced Settings
Enter your Hub admin password when prompted (unless you've changed it, you'll find the default password on the settings card)
Continue to Advanced Settings.
Click on Wireless.
Click 5GHz tab.
Change 'Sync with 2.4Ghz' to No.
Change the name of the 'Wireless SSID' - I added a '_5' on the end.
Save the changes.
You can then select which one you want per device.
03-05-2020 4:05 PM
Thanks for your help. I have alright done that and it made no difference. Any other ideas? Thanks.
Kind Regards
Greg
05-05-2020 9:51 AM
Together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in Speed Faults being fixed. In the meantime, please raise your speed fault online at faults.plus.net
