ADSL 2 / FTTC available on our line?
akfinn
Hi there!
We recently switched from BT where it was a nightmare trying to find out if we could use ADSL 2 or FTTC once again (we did have 5mb fibre at one point, but BT completely messed that up!). I read a forum post here where a user asked if they could enable ADSL 2+ on their line, which was solved. According to samknows, our exchange is WBC 21CN and FTTC enabled. Could a moderator check our line to see if they can enable ADSL 2 at least?
Thank you!
2 REPLIES 2
Fixes: 367
Re: ADSL 2 / FTTC available on our line?
Welcome to the forum.
For security purposes you should not display your phone number on this forum, you should edit your post and remove it... The best way to find out what service you can get is to put your phone number in here.  https://www.dslchecker.bt.com/
SammyM
Fixes: 84
Hello @akfinn,
Thanks for getting in touch. I have checked your connection as well as what is available for your line and replied via the account here.
Please get back to us if you have any further quearies.
 Sammy M - Sheffield Team
