ADMIN Does my profile need a nudge in the righ direction please
- ADMIN Does my profile need a nudge in the righ dir...
Re: ADMIN Does my profile need a nudge in the righ direction please
17-10-2011 12:39 PM
as stated I am in the test socket and have been since i first had a problem a few months ago which you helped me with, i havnt changed anything since then
17-10-2011 12:59 PM
Try a different filter, otherwise I'd suggest raising a fault.
Jojo
17-10-2011 1:02 PM
17-10-2011 1:28 PM
this is a new filter we changed it recently after advice here due to another problem on the 6th of this month
we do have one more new one just got to find it, do i need to reconnect resync or reboot again when it is changed
ignore that of course i need to disconnect lol
jim:quote
17-10-2011 1:35 PM
Quote from: mkc66 ADSL Link Downstream Upstream
Connection Speed 4352 kbps 448 kbps
Line Attenuation 57.0 db 27.0 db
Noise Margin 5.8 db 23.0 db
Connection Speed 2336 kbps 448 kbps
Noise Margin 15.6 db 22.0 db
This is what I was talking about - the default noise margin won't drop on its own until you have several weeks of a stable connection without disconnections and not many errors
17-10-2011 1:42 PM
stats from router
System Up Time 00:01:47
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN pppoa 293 301 0 423 822 00:01:33
LAN1 Link Down -- -- -- -- -- --
LAN2 Link Down --
LAN3 Link Down --
LAN4 Link Down --
WLAN 145M 1312 1246 0 4780 2110 00:01:23
Noise Margin 15.5 db 22.0 db
as i suspected still sync at 2336
17-10-2011 4:33 PM
Otherwise as Jojo suggested you need to raise a low speed fault to get the connection checked out.
18-10-2011 10:56 AM
my noise margin is down a tiny bit today Noise Margin 14.5 db 22.0 db so might give it a few days before
raising a fault as it is soo much hassle, even when i put i am in the test socket all the time i have changed nothing recently and i have replaced filters i am told to do these things again
18-10-2011 3:46 PM
Can you get FEC, CRC and HEC error counts from your router?
18-10-2011 3:53 PM
That seems to have sorted the errors on the line. I'll reset the SNR and see how we get on with that.
Jojo
19-10-2011 10:39 AM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
1789 Kbps
0 Kbps 2000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1789 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :3808 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
these are my router stats today
System Up Time 1 day 20:47:41
WAN pppoa 5380 5561 0 13 58 18:26:37
LAN2 Link Down --
LAN3 Link Down --
LAN4 Link Down --
WLAN 145M 2078770 1533479 0 13325 2163 1 day 20:47:17
Connection Speed 3808 kbps 448 kbps
Line Attenuation 57.0 db 26.0 db
Noise Margin 6.3 db 22.0 db
all seems to be heading in the right direction Jojo hopefully i can get back to the 3500 i had or nearer to it
I'll keep an eye on it and see how we get on
sorry spraxyt I have no idea where to find that info on my router
Quote from: spraxyt Can you get FEC, CRC and HEC error counts from your router?
22-10-2011 11:53 PM
System Up Time 06:39:01
WAN pppoa 242555 311159 0 1706 12164 06:38:11
LAN2 Link Down --
LAN3 Link Down --
LAN4 Link Down --
WLAN 145M 336002 267787 0 12613 1991 06:38:36
Line Attenuation 56.0 db 26.0 db
Noise Margin 3.2 db 22.0 db
also had this email today which says in the next 5 weeks how will i know the change has happened and I have seen many people moaning about the change causing broadband issues.
We have good news for you. Your telephone line is in an area that can now benefit from our new broadband network (this is known as 21CN).
We will be switching your service over to this new network and there will be no need to change any settings on your ADSL modem/router or your username and password. You will remain on the same 'up to 8Mbps' speeds that you have currently but are likely to see a better broadband performance.
24-10-2011 1:45 PM
Your profile is 3000 at the moment but if your sync rate stays at the current 4352 then this will increase to 3500.
Jojo
28-10-2011 6:22 PM
Download Speed
2885 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 2885 Kbps
Your DSL Connection Rate :4352 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 3500 Kbps
31-10-2011 9:43 AM
It has changed to 3500 now.
Jojo
