A rather sad ADSL2 connection...
- A rather sad ADSL2 connection...
Re: A rather sad ADSL2 connection...
06-12-2014 7:33 PM
08-12-2014 7:53 PM
08-12-2014 8:20 PM
10-12-2014 12:26 PM
A to E B to E
Capacitance: 350 NanoFarad 355 NanoFarad
DP Line Length Estimate: 3454 Metres DN Line Length Estimate: 3499 Metres
Celerity: 54.4 dB Line Loss: 47.44 dB
Line Stability: Stable
Fault Report Advised: N
Service Level: 2
11-12-2014 9:06 AM
Well that is only marginally better than before, although the improvement in celerity has helped a bit in improving the speed slightly.
I don't know what errors the engineer was looking at but errors don't seem less or gone! Clearly from the engineers comments and report the 'E' side was poor (and may still be albeit maybe a bit better) but I'm not convinced the 'D' side is anywhere near what it should be, and would be only thing that would have accounted for the extremely poor Fibre performance when it was tried. My gut feeling is a Boost is required.
I also suggest that on any further engineer visits, you switch off the modem/router and only switch back on when they have finished (this may help prevent any undesirable DLM behaviour).
I noticed Tony missed the need to get the Upstream uncapped.
11-12-2014 9:20 AM
11-12-2014 11:26 AM
What is a "Boost" ?
11-12-2014 2:51 PM
12-12-2014 10:51 AM
12-12-2014 12:01 PM
12-12-2014 12:14 PM
13-12-2014 10:03 AM
From the attached graphs, you can see when the upstream was uncapped. The odd thing is the BTW speedtest results have not changed for the upstream:
[tt]Download speed achieved during the test was - 2.81 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 2.93 Mbps[/tt]
[tt]Upload speed achieved during the test was - 0.32Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps[/tt]
[tt]Up time (Days hh:mm:ss): 1 day, 7:54:32
xDSL Standard: ITU-T G.992.3
xDSL Annex: Annex A
Channel Mode: Interleaved
Number of reset: 2
Chipset Vendor info (G.994.1): Local Remote
Country code: B500 B500
Specific: 0000 71C8
System Vendor info (showtime): Local Remote
Country code: 0F00 0000
Specific: 3C61 0000
Bearers generic info DS US
Payload rate [Kbps]: 3318 972
Attenuation [dB]: 53.0 30.2
Margins [dB]: 13.1 5.9
Output power [dBm]: 0.0 12.6
Number of bearers: 1
Bearer 0 DS US
INP [DMT symbols]: 1.13 0.37
Delay [ms]: 7.94 5.88
Depth []: 16 0.00
R: 16 0
G.997.1 Statistics (Current):
Failures:
Line failures Near end
Loss of signal (LOS): 2
Loss of frame (LOF): 18
Loss of power (LPR): 0
[/tt]
15-12-2014 9:04 AM
15-12-2014 8:16 PM
[tt]Download speed achieved during the test was - 2.85 Mbps
Upload speed achieved during the test was - 0.34Mbps
[tt]DSL mode: G.992.3 Annex A
Status:
Uptime: 3 days, 18:08:13
Resyncs: 0 (since 13 Dec 2014 13:44:12)
Downstream Upstream
Line attenuation (dB): 53.0 30.2
Signal attenuation (dB): N/A N/A
Connection speed (kbps): 3318 972
SNR margin (dB): 11.4 6.4
Power (dBm): 0.0 12.6
Interleave depth: 16 0[/tt]
15-12-2014 8:22 PM
