A question to plusnet about their configuratoon
Pk9
Hi
What is PluNet's TR-069 configuration?
Tags (3)
11 REPLIES 11
Anoush
Aspiring Hero
Fixes: 139
Re: A question to plusnet about their configuratoon
Hello there,
TR069 is an industry standard remote management system for end user devices. In our case, we use it to link Plusnet routers to their associated accounts.
It allows for the easy setup of routers to get online initially and should the PPP session ever drop it will usually reconnect automatically because of this system. I believe that we can also push firmware updates when required.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Pk9
I presume TR-069 uses port 7547.
When using the IoT scanner from BullGuard, the said port was open to the external Internet.
I've managed to close said port with port forwarding (7547 in all four columns) but wondering how to stealth said port.  I want to ensure that your TR-069 enabled device does not leave any exposed ports
I'm using the 2704n.  Firmware 7.275.2_F2704N_Plusnet which hides remote management.
Pk9
Never mind.  I've solved the problem by reverting back to my old router that has the option to disable remote management.
Pk9
As reported widely in the media within the last two days the newly discovered  Mirai worm is bringing routers down offline utilising the TR069  industry standard remote management system.
Can PlusNet confirm whether or not their router is susceptible to this attack?
Gel
Aspiring Champion
Fixes: 29
CodeBusters
This is a very good question that should be addressed quickly.
Bookworms
Is there an easy way to check if your router has been attacked?
Oldjim
Resting Legend
Fixes: 63
As I understand it the attack is via misconfigured Tr-064 not directly via TR-069 and the Plusnet router isn't one of those susceptible
In any case the Plusnet routers have a unique login password - unlike many where it is standard
Oldjim
Resting Legend
Fixes: 63
I have just read this http://forum.kitz.co.uk/index.php/topic,19002.msg338425.html#msg338425 which explains how it happened
The issue was with the TR-064 stack not properly checking which interface HTTP requests came from.  TR-064 is only supposed to accept LAN side requests.  The bug allowed TR-064 requests to be injected into TR-069 (WAN) HTTP requests.  The device then assumed that the request was coming come the LAN HTTP server.  In summary, these requests had the ability to open [http] port 80 on the firewall,  thereby exposing the web administration GUI to the WAN side.
Pk9
@Anoush is it true that both telnet and ssh is disabled on the Sagemcom 2704n router?
And TR-064 is not running on the internet facing WAN side? on port 7547.
Pk9
So is the router correctly configured with the Tr-064 server not listening on the same port of Tr-069 port 7547?
Can PluNet's confirm this?
Or is it just a case of the router password being the saving grace?
