A question for my son
- A question for my son
11-04-2008 7:52 PM
Re: A question for my son
11-04-2008 11:24 PM
I suggest turning off the router for 30-40 minutes, then try to connect again. The extended break causes a reset at the exchange which might help.
12-04-2008 10:42 AM
My impoverished son still has a modem (Zoom!). Woukd your switch off recommendation be applicable still?
12-04-2008 11:03 AM
First: bt_test@startup.domain with a password of 'test'
Second - bt_test_user@plusdsl.net (the realm - the bit after the @ sign - should be the same as your son's existing login realm)
password 'test'
Once you have recorded successful connections with both of these logins (you won't be able to see any web pages but if your modem reports a connection you have been successful) you should log back in with your son's existing username and password.
Please let us know if that doesn't help,
[Moderator's note by Peter (PJ): In order to avoid any further confusion from other users I have made the usernames display as standard text, not clickable links]
12-04-2008 12:41 PM
Sorry I am so obtuse.
12-04-2008 12:47 PM
Also it's the actual login for the DSL connection, not the email address. It depends if your son has a router or a modem - if he has a modem, there will be an icon he has to click on to start the connection and start being able to access the internet. It is the username and password for this that needs to be changed.
If he uses a router you will need to log on to the router's admin page in order to change the username - have a look at my post 'my broadband doesn't work' (there's a link in my signature, at the bottom of this post) and go to the 'Authentication' section, that should give you a bit more information.
Hope that helps,
12-04-2008 6:22 PM
How, if you cannot connect, can you send the emails?
12-04-2008 6:45 PM
are USER NAMES to enter into the router or modem in place of the user name that your son currently connects to PlusNet with.
He then needs to re-enter his PlusNet user name, in the form <username>@plusdsl.net, and password.
Doing the above should reset things as orbrey has said.
Edit: stopped user names being clickable.
12-04-2008 9:12 PM
I see where the confusion is - orbrey doesn't want you to click on those user names. The trouble is, a user name is in the same format as an email address, in that it's <someone>@<somewhere>.<something>. So if you click on a user name in a forum post, your browser thinks you want to send an email to that person & helpfully opens up a new email message window for you.
As Paul03 says, what orbrey wants you to do is to give your son a ring & read out those test user names to him, so he can enter them into his connection settings.
My guess is that it's easier for him just to turn everything off for 30mins & then try again. If that doesn't work, get him to ring Plusnet support directly.
Quote Customer Support: 0114 296 5198 | 0845 140 0200 | Broadband Faults Helpline: 0114 296 5188 | 0845 140 0080
12-04-2008 11:25 PM
