A question about microfilters
FIXED- Subscribe to RSS Feed
- Re: A question about microfilters
11-01-2020 1:19 PM
Is it recommended that microfilters be plugged in to all sockets in my flat, even those that are not in use (no phone or other equipment plugged in)
Fixed! Go to the fix.
11-01-2020 1:30 PM
Welcome to the forums, @mashwo67.
You only need microfilters in sockets to which phones or other equipment is connected to.
11-01-2020 1:33 PM
Cheers John.
Also, is it ok to plug my router in to any socket (with a microfilter) or is it preferred that the master socket is used for that?
11-01-2020 1:35 PM
You can use any live socket, but the master socket is best.
11-01-2020 1:38 PM
Thanks John
