A query on running Router Stats
Luzern
Seasoned Pro
I'm using with my Netgear router. At present noise margins are logged at minute intervals. If it's there It is likely staring me in the face, ( Ask OH when I'm looking for the car keys or bus  passRoll eyes), but I'd like to know if and how one can alter the sampling interval to something less frequent.
lingbob
Re: A query on running Router Stats
Yes, it's staring you in the face  Grin
I'm not using RouterStats at the moment so I'm working from memory:
Click on the yellow gear wheel and you'll find it on one of the settings tabs.
Regards .....
Luzern
Seasoned Pro
@road runner  Smiley But blowed if I can see it! Sad
lingbob
Graphs --> Common Settings
Over on the right-hand side there's a box labeled Sample every
Yes?  Grin
Regards .....
Luzern
Seasoned Pro
Embarrassed Embarrassed by my blindness!! Found it Smiley. In some ways a pity that the range of intervals is limited.
