A gander at my connection, please.
Luzern
Seasoned Pro
For quite some time the connection has behaved well, but over last few days it hasn't at all. Here is an extract of the event log of a monitoring program. QLT seems OK.
22/01/201810:49:30	No DSL connection
22/01/201810:50:30	DSL connection restored. SNRMup = 5.9 dB, SNRMdown = 9.0 dB
22/01/201819:37:32	DSL connection restored. SNRMup = 6.1 dB, SNRMdown = 9.1 dB
22/01/201819:38:29	No DSL connection
22/01/201823:18:29	No DSL connection
22/01/201823:20:30	DSL connection restored. SNRMup = 5.9 dB, SNRMdown = 9.0 dB
22/01/201823:21:29	No DSL connection
23/01/201810:10:30	DSL connection restored. SNRMup = 6.1 dB, SNRMdown = 9.1 dB
23/01/201810:11:29	No DSL connection
23/01/201810:12:31	No DSL connection
23/01/201810:13:29	No DSL connection
23/01/201810:16:29	No DSL connection
23/01/201810:17:29	No DSL connection
23/01/201810:18:30	DSL connection restored. SNRMup = 5.7 dB, SNRMdown = 8.9 dB
23/01/201810:20:30	DSL connection restored. SNRMup = 6.1 dB, SNRMdown = 9.1 dB
23/01/201810:21:29	No DSL connection
23/01/201810:23:29	No DSL connection
23/01/201810:24:31	Unable to login to modem/router
23/01/201810:25:30	DSL connection restored. SNRMup = 6.0 dB, SNRMdown = 9.1 dB
23/01/201810:26:29	No DSL connection
23/01/201810:29:30	DSL connection restored. SNRMup = 6.2 dB, SNRMdown = 9.2 dB
23/01/201810:31:30	DSL connection restored. SNRMup = 5.9 dB, SNRMdown = 9.1 dB
23/01/201810:33:29	DSL connection restored. SNRMup = 5.9 dB, SNRMdown = 21.6 dB
Average error rates for 23 Jan 2018
CRC erors per hour:  551 Down,  11.9 Up
FEC erors per hour:  0 Down,  0 Up
HEC erors per hour:  1985 Down,  2.47 Up
ES per hour:  43.6 Down,  6.33 Up
SES per hour:  19.5 Down,  0.08 Up
Fixes: 16
Re: A gander at my connection, please.
Hi @Luzern and thanks for getting in touch.
I'm sorry to hear that you're experiencing drops in connection - I can see these reflected in the history of your connection over recent weeks.
I've tested your broadband connection and haven't found any external fault on your line. This usually means that the issue relates to something within your premises.
In order to narrow down the cause of the problem I'd recommend that you undertake the troubleshooting which can be found here.
If you follow this through and still experience drops in connection when you're connected to the test socket I'd recommend that you raise a fault here.
Hope this helps.
Best Wishes,
Dave
 Dave G
Luzern
Seasoned Pro
Will try test socket, but not that easy for 80+ chap.Sad
Getting worse
CRC erors per hour: 549 Down, 12.1 Up
HEC erors per hour: 4026 Down, 10.1 Up
ES per hour: 43.6 Down, 7.15 Up
SES per hour: 20.7 Down, 0.15 Up
Fixes: 441
Sorry for the inconvenience caused @Luzern
It might also be worth finding out if there's any noise or crackling on your phone line by dialling 17070. If there is, I'd recommend reporting it to your phone provider to investigate the line.
Failing that, best to report a fault to us at faults.plus.net or using the link Dave has provided.
Luzern
Seasoned Pro
17070: there's no noise AFAICT. in truth I had checked that before posting. Last evening plugged into test socket, and errors are minimal. Before going much further I'm thinking of getting new Ethernet cable, as age is suspect.
Luzern
Seasoned Pro
Someone (private) is coming out to examine/ revamp my set up.
OT? Interleaving depth is a funny one "511". I thought depths went up in 16 multiples.
Fixes: 441
Let us know how you get on with this.
Luzern
Seasoned Pro
I will. Regarding my comment on the massive interleave depth, has any got an answer how it could be so strange and high?
Somewhat funny, certainly not "ha-ha" is that I am back on fast path with much the same SNRM and speed.scratching-head-smiley-emoticon
Fixes: 20
It's difficult to say anything much about a single number without seeing all the rest of the stats.
The possible interleaving depth values for ADSL2/2+ are 1, 2, 4, 8, 16, 32, 64 and then 96, 128, 160, 192, 224, 256, 288, 320, 352, 384, 416, 448, 480, 511. Yes 511 is listed as the highest one.
The interleaving depth figure itself is not particularly important, the more important figures to look at are the INP and delay values. Without seeing the rest of the stats, I'd guess that the interleaving depth of 511 was due to being on a banded profile with a higher than usual INP level (more error protection).
Luzern
Seasoned Pro
I have attached PDFs of complete stats of situation prior to troubles, with 511 interleave and, lastly on current fast path.
Luzern
Seasoned Pro
Just noticed the Event log has taken a bad turn.Ticked off
Fixes: 16
Hello @Luzern
Sorry to hear you are experiencing a problem with your connection.  We can see that your connection is dropping a lot, which is causing it to become unstable and the line speed to be reduced automatically, as a way of stabilising it. This is done automatically by a DLM software which makes changes to your line to try to keep you connected.
image151800375299717 days of connection
The drops could be caused by either internal wiring, equipment or a fault on the line. Please can you advised if you managed to move your equipment into the test socket, which you can use the guide here to locate it. We would also ask you try an new microfilter and alternative router to rule out your equipment.
If you have tried the suggestions above and the issue is persisting we would recommend raising a fault here. Please let us know how you get on. Smiley
 SammyM
Luzern
Seasoned Pro
@SammyM
thanks for replying.Smiley As it happens, I am waiting for my wiring to be revamped with SSFPs.
Fixes: 16
Hello @Luzern
Thanks for letting us know. Cheesy
 SammyM
Luzern
Seasoned Pro
Wiring was revamped on 13 Feb mid morning with SSFP in place of filters, and I was assured that internal phone set up was OK and that no line fault had been found. Apart from some disturbance and drops on 15th the errors a greatly reduced. Can the banding be removed, please, and the very high interleave depth reduced? If you have observations post 13 Feb, you will doubtlessly pass them on.
OT can you confirm costs of changing to Fibre without phone until my LRS with BT has run its course? Is there any cost benefit in not accepting the offered router?
Average error rates for 20 Feb 2018
CRC erors per hour:  0.69 Down,  10.1 Up
FEC erors per hour:  1784 Down,  62.2 Up
HEC erors per hour:  4.78 Down,  12.4 Up
ES per hour:  0.15 Down,  6.85 Up
SES per hour:  0 Down,  0.05 Up
