A gander at my connection, please.
- Re: A gander at my connection, please.
13-03-2018 3:09 PM
The title of a thread form a newish contributor is, "Anyone regret moving to Plusnet ?". I have to say that after many years of satisfaction, the continued banding of my connection is making me say, "Silly person! Do you need to ask"?
For goodness, sake! Can nothing be done to force removal?
13-03-2018 3:37 PM
@Gandalf - can you please spread a little magic here please?
13-03-2018 3:47 PM
13-03-2018 5:46 PM
Thank you! Resync about 1.25 hrs ago. dpwn speed 7578 kbps. ES in telnet 43; now at 1:55 ES 48.
What's that telling me?
13-03-2018 6:05 PM
In isolation, not a lot! Please post the full set of router xdsl stats.
14-03-2018 10:42 AM
@Townman Sorry about delay, but last evening I could not upload, and BT tester was showing error 2032 and weird figs. Anyway FWIW yesterdays post banding data is attached. Hope it's what you want.
Router, because of above, was off overnight, and this morning I reorganised the tangle of cables, and am using the cat 5e twisted pair DSL recommended earlier. I shall upload today's data in 2 /3 hours.
14-03-2018 11:48 AM
Here's a copy of your stats from our tests if it helps:
Profile Info: | WBC 160K - 24M Medium delay (INP 1) 6dB Downstream, UC Low delay (INP 0) 6dB Upstream (ADSL2+) |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 25.3 | 47.5 |
SNR Margin: | 6.0 | 6.1 |
Errored Seconds: | 12 | 0 |
HEC Errors: | 57 | |
Cell Count: | 402270 | 775602 |
Speed: | 912 | 7611 |
Maximum Stable Rate (KBPS): | 6240 | Fault Threshold Rate (KBPS): | 4992 |
Mean Time Between Retrains (Seconds): | 58449 | Mean Time Between Errors Upstream (Seconds): | 812 |
Indicative Line Quality: | G | Mean Time Between Errors Downstream (Seconds): | 58449 |
Copper Test Details | |||
A to E | B to E | ||
Capacitance: | 295 NanoFarad | 298 NanoFarad | |
DP Line Length Estimate: | 2725 Metres | DN Line Length Estimate: | 2818 Metres |
Celerity: | 42.3 dB | Line Loss: | |
Line Stability: | Stable | ||
Fault Report Advised: | N | ||
Service Level: | 2 | ||
BRAGOutcome: | NA | ||
Faceplate: | Not Detected |
14-03-2018 5:12 PM
@Gandalf - Thanks - this is looking fairly good now!
Router stats look darned good, DS is very good for the line's attenuation and US is about as good as it gets.
BTw speed test is disappointing, though the results look very suspect. Suggest that you give these a run on and off to see what they report. Also try the Thinkbroadband speed tester.
As for router stats, please keep this running and post graphs rather than stats from times when the lines look less than clean. Particularly look out for spikes which take the SNRM down to zero and looks to see if synch was lost at the same time.
I have seen nothing in this journey which yet points to a specific issue which has been eliminated; therefore there is every chance that some event will cause the line to become banded again. Comprehensive stats might provide some insight to the event which triggers this.
14-03-2018 6:55 PM
Thank you @Townman @Gandalf Just out of curiosity, what is the Celerity reading? Dictionary definition "swiftness of movement" doesn't seem to fit. Upstream MTBE is low cf. down. Does up MBTE ever have adverse results for a connection?
15-03-2018 12:32 AM
Mean Time Between Errors indicates how many errors you are seeing in a given time interval. Consider also that DS is transferring more bits in one interval than does US. At this stage I’d not worry about the figures.
15-03-2018 7:19 AM
Not worried just curious. as I said.
27-03-2018 9:26 AM
An odd OT question. Does Routerstats, either version, work with any VDSL router, preferably with some ease? The routers listed , unless I'm being blind, don't seem to show anything.
BTW rock steady now.
27-03-2018 12:49 PM
I have RSlite working with a ZyXEL VMG8924-B10A running in VDSL mode ... but RS lite does crash a lot!!
27-03-2018 12:58 PM
27-03-2018 5:07 PM
I think people tend to use DSLstats instead.
