A different email problem
- A different email problem
- « Previous
- 1
- 2
- Next »
Re: A different email problem
03-09-2007 11:53 PM
Quote from: dave …We can run remote line tests and see what comes up. Which I think is the best thing to do, report it as a fault and see what the woosh test comes back with and then take it from there.
I assume you will be taking that offer up. I wonder if the best chance of a fault being diagnosed could be for the tests to be done in the presence of marginal noise margin during the day when higher values are normally expected.
04-09-2007 12:00 AM
Plusnet Technology
04-09-2007 12:03 AM
Quote from: dave I assume you will be taking that offer up. I wonder if the best chance of a fault being diagnosed could be for the tests to be done in the presence of marginal noise margin during the day when higher values are normally expected.
I was thinking it may work better if I run three BT speedtests when the router syncs under the fault threshold. That way it is clear there is a fault. However given how variable my line is this could take a while.
Anyway I need some sleep! I'll report a fault through the portal tomorrow.
James
04-09-2007 12:13 AM
Don't BT require their three tests to be done at different times of day? Could lose the opportunity.
04-09-2007 9:55 PM
Well my router is synced again below the fault threshold on my line and so I have raised a ticket (#22767586).
Hopefully something will get fixed this time!
James
04-09-2007 11:52 PM
Plusnet Technology
09-09-2007 11:08 PM
Given that my line syncs above the fault rate during the "day", support don't seem to be keen on raising a fault with BT. However as soon as it gets later in the "day" the line resyncs at a far lower rate. Currently my line is synced at 2880 which is an all time low (the fault rate is 3160)
My line used to sync in the very high 4000s during the evening, and so there has been a very considerable decrease in sync rates.
Has anyone got any suggestions on how I can get the issue escalated to BT?
09-09-2007 11:35 PM
10-09-2007 9:38 AM
One of the Analysts has replied to your ticket stating that we can send it through to BT as long as you are aware of any possible BT charges should BT find a fault to be with your equipment.
10-09-2007 10:44 AM
Cheers for the response.
I have just posted a reply to the ticket.
For some reason the 'fault threshold rate' has been changed on my line - which I don't agree with.
In principal I am perfectly happy to pay BT is need be, however I would first like to agree the fault threshold rate so we all know what rate my line should be syncing at.
10-09-2007 11:14 AM
I've replied to your ticket. Long and short is that the FTR can be changed over a period of 30 days.
17-09-2007 8:55 AM
Well a BT engineer is going to come out.
I see from the ticket though that 'BT has not been able to identify a fault'. Can anyone at Plusnet given me an indication why? I would have thought that if the sync < FTR then it's pretty obvious something is wrong!!
James
17-09-2007 9:18 AM
07-11-2007 3:58 PM
Quote from: JEB I ......... then noticed an option in the router config to open or close instant messaging ports. 'Closed' was selected by default, but when I changed this to 'open' the emails worked fine.
Wow! This has just solved a problem I've been having intermittently with sending attachments since changing from a Netgear DG834GT to a DG834PN. I don't remember offhand if I had it as open or closed before changing routers or if the older router even had that option except deep in the firewall settings but it seems to have done the trick.
Many thanks!
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
07-11-2007 6:36 PM
- « Previous
- 1
- 2
- Next »
