A couple of questions about Fibre broadband
- A couple of questions about Fibre broadband
19-12-2012 1:30 PM
Download speeds on fibre are quoted as up to 38Mbps for Essentials and up to 78 Mbps for the Unlimited package. If I look in the Product Change for Unlimited, the speed estimate for my line is ~58Mbps, but 40Mbps for Essentials fibre. Is the 40Mbps realistic given that I can only get ~2Mbps on ADSL?
I currently have a TG582n supplied by Plusnet, which has a USB port which I am using to connect a drive shared across all devices on my home network. If I change to Fibre, could I still use this router or would I need a replacement, and if the latter would it also have a working USB port?
My other car isn't a Ferrari
Message 1 of 6
(1,537 Views)
5 REPLIES 5
Re: A couple of questions about Fibre broadband
19-12-2012 1:32 PM
ADSL speeds have no relation as that's distance to the exchange that affects it rather on fibre it's distance to the cab.
if your estimate is 40 then it's a reasonable expectation that you'll get it.
you'll need a new router and they don't have a working usb port, afaik.
Message 2 of 6
(864 Views)
19-12-2012 1:42 PM
They still supply the 582 for fibre, and mine had usb ports (both of them)
Message 3 of 6
(864 Views)
19-12-2012 1:57 PM
Quote If I change to Fibre, could I still use this router
Its possible to configure the TG582n for FTTC using Telnet see here http://community.plus.net/forum/index.php?action=post;quote=914793;topic=106578.32;num_replies=56;se...
I would also assume that it could instead be flashed with the FTTC firmware, would need someone from PlusNet to confirm this...
Message 4 of 6
(864 Views)
19-12-2012 9:11 PM
My TG582n was replaced with a fibre TG582n foc when I upgraded to fibre. I quickly replaced it with an Asus RT-N56U because the wireless speed loss with the 582n was dreadful.
Message 5 of 6
(864 Views)
19-12-2012 9:18 PM
My fibre was installed 8 days ago, the expected speed was 32Mb, we are getting 38Mb, on adsl we only got 3Mb. I was supplied the fibre TG582n router, it does have a usb port and I have it working sharing a drive on the network.
Message 6 of 6
(864 Views)
