A Few Questions Re My New Thomson Router
- A Few Questions Re My New Thomson Router
04-06-2010 2:00 PM
After the nightmare last week with what turned out to be a defective BT1801HG router my IP profile plummeted, but having used the stop gap Speedtouch 330 ADSL modem since Monday night (31st May) it has recovered to 4000kbps. This is still much less than the best achieved when the old router was last working properly so would it be a fair assumption to say that my IP profile will gradually improve once the new router 'establishes itself'?
Also, the Thomson Broadband Connection screen shows that my connection type is G.992.1 annex A. Does this mean that I am now on 21CN (the BT1801HG having been incompatible) or do I need to physically change something? Or indeed do Plusnet need to change something?
Finally (for the moment at least) I am not currently using the wireless option but it appears to be enabled. I have been supplied with a 'wireless key' so does this mean that this needs to be input before anyone can use my wireless connection (?) as obviously I don't want to become a handy wireless hotspot for anyone nearby!
Thanks for any suggestions.
Re: A Few Questions Re My New Thomson Router
04-06-2010 2:07 PM
04-06-2010 2:08 PM
The wireless is set to WPA (I believe) by default and anyone trying to connect to it would need to use that unique key
Regarding 21CN and ADSL2+ the router should pick that up automatically I believe but that needs your exchange to be enabled and Plusnet to transfer you to it (and you need to be on a suitable product ;D)
04-06-2010 2:14 PM
I'm not so bothered about turning the wireless off if the password is de rigeur. Who knows I might use it myself one day but at the moment none of my equipment has wireless capability - apart from the mouse!
As for 21CN, Boston exchange was enabled in April as I recall, and Plusnet advised me some time ago that I would be switched to 21CN when that happened so until the problem with the old router arose I had naturally assumed that I was already on it.
Anyway it's early days yet and at least it is nice to know that I have a stable connection again.
04-06-2010 2:19 PM
Moving to 21CN won't show up as a change to your connection in your router. It is only when Plusnet place a specific order for ADSL2+ will it happen
04-06-2010 2:23 PM
Quote from: Oldjim 21CN and ADSL2+ are two different things although you can't get ADSL2+ without having 21CN first.
Ah well c'est la vie!
BTW as far as router stats go, this is as much as I can find in the Event Log at the moment, bearing in mind it has only been switched on for one hour....
04-06-2010 2:28 PM
Unless you go for a retrain it will take several weeks to drop back to 6dB with a significant speed increase
Off topic- that isn't normally where we get them from but that is much more informative as it is the figures immediately after connecting
Just to add - for the future - you can attach images using the Additional Options and Attachments link when you post rather than going through Photobucket
04-06-2010 2:36 PM
04-06-2010 3:17 PM
You appear to be synching at 6432kbps so your IP Profile should rise to 5000 within 3 days ( possibly quicker ). As Jim says, it will take longer for your target SNR to drop and the speed to increase much more.
At least it's a big improvement over the speeds with the 1801HG
04-06-2010 3:21 PM
I can reset your SNR if you wish? This would set the SNR to 6db, and should give you a decent speed increase. It does reset the 10 day training period though.
04-06-2010 7:18 PM
Quote from: Mand Hi there,
Well I was getting very close to 5Mbps before the old router crashed and actually had over 5.3Mbps last summer so my line can certainly support the higher speeds. On the other hand I don't want to rock the boat too much so if you think I would see some benefit then by all means go ahead, otherwise I am happy to wait and see.
Thanks for looking into this for me.
Brian/Spruance
