9225 kps at Router but only 6400Kps speedtest at computer - Why?
- 9225 kps at Router but only 6400Kps speedtest at ...
11-02-2010 1:57 PM
Im on Premium and ADSL2.
Getting 9225 kps at router but only 6400kps at computer (using speedtest)
Does anyone know why this may be so - seems like a big difference to me
thanks in advance
Re: 9225 kps at Router but only 6400Kps speedtest at computer - Why?
11-02-2010 2:02 PM
If your router continues to connect at 9225 then that profile will increase to 8000 and the speeds you see on speedtest sites will also increase too.
11-02-2010 2:57 PM
Should my modem continue at 9225kps will my speeds increase automatically to 8000kps and if so how long would this normally take ?
thanks
j
12-02-2010 8:03 PM
The profile change should be automatic, taking 3 to 5 days. The change is done by the BT wholesale DLM. Sadly in the downward direction the DLM reacts within 75 minutes.
15-02-2010 2:14 PM
16-02-2010 7:06 PM
Where do I look too see what profile I am on?
16-02-2010 7:31 PM
Check the value shown as 'Current line speed' in the Member Centre here to verify BT have passed that onto Plusnet.
16-02-2010 8:30 PM
For your connection, the acceptable range of speedsis 1000-99999 Kbps.
Additional Information:
Your DSL Connection Rate :15583 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
IP Profile for your line is - 13000 Kbps
and on plus.net member site
Telephone number:
Phone exchange:
NEWPORT
Estimated line speed:
8 - Checked on 2009-12-04 07:29:57
Current line speed:
7150
16-02-2010 10:53 PM
Hopefully a staff member will see these posts and give it a nudge if the automatic-update process hasn't done the necessary by tomorrow.
18-02-2010 8:39 AM
Ive had a steady and consistent 9224kps at my router during this period.
Can someone tell what i can do to get the IP profile raised to 8000kps
thanks
see latest BT test below
Download speedachieved during the test was - 6176 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Your DSL Connection Rate :9224 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 14.49:22.86:62.65 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
18-02-2010 10:13 AM
Your profile on our side is now set to 13000 and matches the IP profile.
18-02-2010 10:53 AM
Im sure this may help
Ive just checked the BT speedtest again and its still showing 7000kps
How to i get BT to raise their IP profile to 8000kps - this does not appear to have occurred automatically and sounds like the issue
Sorry if i sound a bit fick but im not really an expert in these areas
thanks
18-02-2010 10:55 AM
18-02-2010 11:15 AM
18-02-2010 12:04 PM
