9 days, and I still can't see my daily usage!
- Re: 9 days, and I still can't see my daily usage!
07-08-2012 3:02 PM
Oh, the help line is polite, but their pie crust promises and lame excuses are wearing a bit thin now.
I reported the issue 9 days ago, and still I can't see my daily usage, this is important when streaming and downloading is heavy, but those in control can't see this. All I keep getting is 'we're working on it'
And no one can, or will, explain why this has happened.
All I know is it started at the date of a new billing period.
Help.
Help.
Message 1 of 8
(1,579 Views)
7 REPLIES 7
07-08-2012 4:36 PM
Hi Wiz,
We have a problem with viewing usage at the moment for a number of customers. Unfortunately no ETA at the moment, we're working on it and will update as soon as we have more information.
Sorry I can't give any further information into this at the moment, I will keep you informed.
Chris
Chris
Message 2 of 8
(728 Views)
07-08-2012 9:19 PM
Thanks for the prompt reply Chris, even if its no help to me atm, I can only trust your word that it will get sorted asap..
Ta very kindly.
Ta very kindly.
Message 3 of 8
(728 Views)
08-08-2012 7:55 PM
What grates with me is that when phoning Plus Net, the assistant can see my usage, and informs me of the GB used, but I can't see it, thats is the most annoying thing and worry.
Maybe a nice new free router would solve this, I think it would be a nice gesture.
Message 4 of 8
(728 Views)
09-08-2012 10:49 AM
Your worried about 9 days, I haven't been able to see any stats for many months now and just get told it will be fixed soon.
Message 5 of 8
(728 Views)
09-08-2012 11:24 AM
On some affected accounts we can see the usage, unfortunately the workaround we have to use to do these means we can't see any breakdown of peak/off-peak without manually calculating it.
Message 6 of 8
(728 Views)
15-08-2012 2:26 PM
Quote from: barberriley Your worried about 9 days, I haven't been able to see any stats for many months now and just get told it will be fixed soon.
You should now be able to see your usage.
Quote from: Wiz I reported the issue 9 days ago, and still I can't see my daily usage ...
Your problem's slightly different Wiz and we're still working on it.
Message 7 of 8
(728 Views)
16-08-2012 2:34 PM
@Wiz
Message 8 of 8
(728 Views)
