888kbps upload 'bug'
- 888kbps upload 'bug'
10-02-2012 8:48 PM
Wondered if anyone had any ideas. i have a Netgear DG834PN Router on the latest firmware. It holds sync on my line like glue, even thought the DLM insists on a 3db margin on the line
ADSL Link Downstream Upstream
Connection Speed 7968 kbps 888 kbps
Line Attenuation 46.0 db 23.1 db
Noise Margin 2.8 db 10.5 db
Re: 888kbps upload 'bug'
10-02-2012 9:09 PM
I think that as long as you are on ADSL2/2+ then PN can selectively control interleaving for the upstream and downstream seperately, so should be able to get the cap lifted for you on Monday.
For note, here's our stats:
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,051 / 4,690
Line Attenuation (Up/Down) [dB]: 26.0 / 48.5
SN Margin (Up/Down) [dB]: 5.0 / 5.0
Alex
11-02-2012 8:30 AM
Quote from: houlton23 I believe it it limited to 888kbps when interleaving is turned on.....I think that as long as you are on ADSL2/2+ then PN can selectively control interleaving for the upstream and downstream seperately
Interesting snippets of info. Thanks
12-02-2012 4:53 PM
13-02-2012 12:08 PM
What do you want me to oblige, to have interleaving on downstream but off on upstream?
Jojo
13-02-2012 7:15 PM
Can we try interleaving OFF on Upstream only, and see how that goes please
Rgrds
14-02-2012 11:24 AM
I've just done that now. We normally say allow 24 hours to take effect.
Jojo
18-02-2012 9:28 PM
nothings happened yet.... Do I have to do a manual resync?? I thought that the change would have brought about an automatic resync of the connection.
20-02-2012 1:19 AM
20-02-2012 5:20 PM
22-02-2012 8:46 PM
Still upload stuck at 888. DMT tool still thinks I have interleaving on Up and Downstream. Depth 64 down, 8 up
Synced at 8400 Down with a 3dB margin, and 888 Up with a 12dB margin.
23-02-2012 9:15 AM
I'm sorry to say that unless something went funky with the order, I may have asked for the wrong profile. I'll do it again now and double check before I click submit.
I can only attribute this to a blonde moment
Jojo
23-02-2012 6:31 PM
I will see how things go after the order completes. Will you let me know?
