85million FEC errors
lh
plusnet isp; router reports 85million FEC errors in 6 days.
s/n down :10.5dB
attenuation 57dB
about the same as BT last year. ANy suggestions or am i stuffed with poor line?
3km from rochdale exchange.
Fixes: 16
Re: 85million FEC errors
Is it causing you a problem?  Huh
lh
service is 8mbps; 1.6mbps is a bit shabby. UK ave around 4mbps?
adie:quote
Fixes: 16
Servivce is UP TO ..... 8mbs.... Your particular service speed is governed by the distance you are from the exchange, and to a point, the SNR  on that line... If the line is noisy as a telephone line, then you may experience drops in synch speed, and should report it as a VOICE fault to PlusNet.
I am about 4 Km from my exchange and I am getting between 1.2 AND1.4 meg speed... My Download attenuation is 63.5db and my current SNR is 4.8 varying between 6.5 and 3.5 during a 24 hour period..... I don`t worry about the FEC figures... My line is supposed to support 2 megs maximum.... my current synch speed is 1952kbps... it has been up to 2016 kbps but my speed has never been above 1.6megs
lh
voice is ok. sounds like you are in the same boat. STuffed until a cable provider moves nearby.
Fixes: 16
Yup!>. The house is wired cabled  for Virgin, but I don`t intend going that way !... I`m happy with a nice stable connection.... speed is not an issue with me, as I don`t do gaming.... !  just email and normal surfing, with some youtubes ....  Smiley
itsme
85 million, thats not many
Uptime: 8 days, 1:23:06
Modulation: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 959 / 3.069
Data Transferred (Sent/Received) [MB/GB]: 377,23 / 1,32
Output Power (Up/Down) [dBm]: 12,5 / 0,0
Line Attenuation (Up/Down) [dB]: 27,5 / 48,5
SN Margin (Up/Down) [dB]: 5,5 / 4,0
Loss of Signal (Local/Remote): 6 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 54 / 0
FEC Errors (Up/Down): 0 / 2.246.948.819
But, but, but...
If those '.' are meant to be ',', then you're running at 3200 FEC errors per second.
I'm not convinced it would be working at all with that kind of rate!
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Quote from: lh
That's 163 per second, which sounds quite a lot - but of course FEC errors are the ones that are correctable.
How does the CRC figure look?
Plusnet Customer
lh
FEC Errors (Up/Down): 46 / 85,396,019
CRC Errors (Up/Down): 46 / 1,669
HEC Errors (Up/Down): 38 / 1,209
that number of errors suggests something amiss, but i cant say i see any problem browsing
That CRC level is about 10/hour, which seems to be perfectly manageable - you're not likely to see much of an issue when you are browsing or downloading.
I recently went to non-interleaved, but on a rather better line. I went from 30 FEC per hour (and almost no CRC) to roughly 30 CRC per hour. My errors are very sparse, so each error that was correctable with FEC became a full CRC error without.
If your errors are spread out a lot, then the 85 million FEC errors could become 85 million CRC errors; if the errors occur in dense bursts, then this could reduce to, at best, 1.25 million CRC errors.
Over the 6 days, that would be a theoretical range of between 2 and 164 CRC per second.
However, the way the data is carried on the line means that 60 CRC errors per second is 100% failure, so you can't get higher than that. At the very best, you will be guaranteeing yourself (2/60) errors, or 3.3%, but probably rather higher.
In this case, I'd say the the FEC correction is doing its job extremely well. I would only turn it off if I was in a very experimental mood, and willing to accept that it might make the line unusable for at least a day, and then have a knock-on effect on the IP profile even after it was turned back on again.
And, unfortunately, turning interleaving off also turns off FEC.
Plusnet Customer
lh
i expect i will leave things as is. Copper cable means winners and losers dependent on line length.
i can live with it until fibre arrives or i move house.
thanks for all the feedback.
