800 ping tonight shocking
St3
Aspiring Champion
Fixes: 5
Ive only been with plusnet 7 days now up to tonight my online gaming has been fine but tonight ive had major lag and 811 pings. Ive just had house rewired all cables and bt sockets are new.... before u ask ;E  Ive a new pc and new router,.
Re: 800 ping tonight shocking
Pings to where?  I know that there was a power outage in USA this morning that affected some of the major server farms, so anything hosted on eastern coast in US will be laggy till the congestion is cleared
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
St3
Aspiring Champion
Fixes: 5
in battlefield 3 i was on a uk hosted server and i ping normally at 21ms, only i out of 15 others could not move and when i checked ping it read 811ms. its only affected me.
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi ukste,
If you've been with us for 7 days, your line will still be in the 10 training period. If you give it 3 more days, your line should have settled down.
If you've got any further issues after that, be sure to let us know and we'll look into it for you Smiley
Chris Pettitt
Cloud Environments Engineer
rongtw
Fixes: 12
Hi ukste, i was on BF3 severs last night but my ping was only 20ish never any higher ,  have you any background program's running ?  AV updates ? or windows update on ?
St3
Aspiring Champion
Fixes: 5
na none mate, ive been online gaming a few years now so those were first things i ckecked for Wink
rongtw
Fixes: 12
one other thing to try is to Disable UPNP on your router , if things havent changed  Wink
what connection are you on ? fibre or copper
St3
Aspiring Champion
Fixes: 5
im not on fibre so i must be on copper Wink it could well be the 10 training period today is my 10th day, pings have been back to normal and speeds are normal, ive had 3 connections drops but i guess this might be part of the training period .
Looking at your connection, it look's like it has settled down. It's just a case of monitoring it now to see how it goes.
Let me know if you have any issues with your connection.
St3
Aspiring Champion
Fixes: 5
Im happy with current test ive just ran.
But that test was futher away, when i run a speedtest to a server which is an hours drive from me i get this...
I thought if i ran a speedtest with a server closer to me, my speed would be higher and my ping lower as they aint travelling as far. But when i run speedtest to locations down south eg london areas, my ping is much lower.
just out of intrest is this normal?
Fixes: 167
Although it's closer to your premises, it's actually further away from the equipment your connection terminates on. For a ping to that Carlisle server the traffic has to go to London and then back to Carlisle, so it's right that the ping is higher.
 Chris Parr
 Plusnet Staff
St3
Aspiring Champion
Fixes: 5
is the 35 ping about right for my connection and distance? As im an online gamer having a lower ping can sometimes be just as important as having a good speed.
@ ukste, far better to ping from a Windows command prompt (or equivalent in other OSs), I usually use ping bbc.co.uk as that indicates what you get to the real world beyond the PlusNet network but close enough to the London datacentres that it isn't normally too affected by other factors.  Speedtest.net pings are not always that reliable.
Call me 'w23'
Fixes: 5
35ms ping is a good ping.
Kelly Dorset
Broadband Service Manager
rongtw
Fixes: 12
This is what i get from Yorkshire  Wink
