80/20 FTTC only 40meg at cabinet
- 80/20 FTTC only 40meg at cabinet
20-05-2013 8:57 PM
The 80/20 order was placed by Steve in the HLC dept. But my speeds didn't change.
The OR engineer has confirm the cabinet speed is only at 40Mbps
As far as I know the FTTC cabinets are connected by fibre straight to the exchange at around 10Gbps.
Why haven't I seen any improvement in speed? (Steve has asked OR but they don't seem willing to reply!)
Re: 80/20 FTTC only 40meg at cabinet
21-05-2013 9:10 AM
21-05-2013 1:12 PM
Welcome to our community forums,
I've checked over your connection and and can see that your line estimate is 25.2Mb/s, the package you're on does allow for speeds of up-to 80Mb/s, so whatever your line can support.
If you put your phone number in the link Anotherone has provided above you'll see your line estimates.
21-05-2013 10:14 PM
dick:quote
21-05-2013 10:41 PM
22-05-2013 7:00 AM
Quote from: retsil With the upgrade of 80/20 only being a change to the 17a profile why hasn't the cab speed increased to 80mbps?
And do you mean "the cab speed"? You have no means of knowing what the speed is at the cab, only an engineer can check that.
Unless the Cab is almost in your front garden and your line goes directly to it, you won't get 80Mbps. In most cases your line goes to your original PCP first, then to the Fibre Cab.
22-05-2013 10:45 AM
Quote from: njay Did you mean 49mbs in your last post?
No I meant 49Mbps or 49 megabits per second if you don't like the use of abbreviations.
22-05-2013 10:46 AM
Quote from: Anotherone
The engineer has been to the cab and checked, that's how I know.
I'm less than 200m from the cabinet, so should expect to get nearer 80Mbps than my current 36Mbps.
22-05-2013 10:51 AM
22-05-2013 10:58 AM
The quoted speed at the cabinet from Retsil is correct (we were told this by the engineer).
As there isn't (imo) any logical reason why this would be the case we are continuing to chase.
22-05-2013 10:59 AM
If the engineer said that he was only getting 49Mbps at the Cab, was he talking sync speed or download speed? Because if it was sync speed then he should have been addressing a fault on the DSLAM.
If he was actually referring to download speed and not testing your connection to Plusnet but a generic BT test, then he should have be reporting to his bosses about BT network congestion.
If he was testing your connection to Plusnet then a check should have been made of your Current Line speed (Login required) which should equal the BT IP profile for your line obtained from the BTw Performance test (ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test.
You can do a Copy and Paste of the results and post here (no need to grab an image).
Edit: having just seen your post James, clearly the engineer should have pursued the faulty DSLAM issue unless it's still unclear what speed the engineer meant!
22-05-2013 11:32 AM
Quote from: Anotherone If the engineer said that he was only getting 49Mbps at the Cab, was he talking sync speed or download speed?
Could also have been 'Attainable speed' which is also reported by a modem (which the JDSU contains)?
22-05-2013 11:33 AM
22-05-2013 12:51 PM
Quote from: retsil
That wasnt what I was referring to so no need to get stressed about it
I meant that you quoted 49Mbps which is above the download rate for 40/10 service and suggested to me that the cabinet was already 80/20.
Sorry for the confusion by missing out the b as my reply should have said "Do you mean 49Mbps in your last post?"
22-05-2013 12:55 PM
