7800n Ewan Throughput
- Capped @ 66.5MB
26-12-2013 5:53 PM
I am unable to connect to the fttc modem directly creating a PPPOE connection within windows 7.
is this normal as I am looking at a possible router replacement or all in one solution like a 2750
Download speed achieved during the test was - 66.47 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload speed achieved during the test was - 16.76Mbps
Re: 7800n Ewan Throughput
26-12-2013 6:49 PM
If for some reason you want to go computer >> modem, that works fine as well. If that fails, you have finger trouble in your Win7 settings.
27-12-2013 10:07 AM
I think the 7800n is bottlenecking
27-12-2013 10:31 AM
You are quoting a file transfer speed of 105 megabytes per second presumably over a Gbit LAN
But then you are talking about the modem and I fail to see the relevance of that
I assume that by WHS you mean Windows Home Server and if so how are you connecting your device to that - via the router LAN or via a direct connection
27-12-2013 1:29 PM
27-12-2013 2:16 PM
wnload speedachieved during the test was - 66.77 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
Upload speed achieved during the test was - 14.58Mbps
Any reason why I am not getting 70MB + ?, not trying to be funny here either
Capped @ 66.5MB
27-12-2013 3:38 PM
Have tried direct connection to the ECI modem also
seems to me when I hit around 66.5MB it bounces back down and starts to increase in throughput
can someone check it out for me please
user name ephid0r
Re: Capped @ 66.5MB
27-12-2013 3:51 PM
Ex-Broadband Service Manager
Re: Capped @ 66.5MB
27-12-2013 4:11 PM
Re: Capped @ 66.5MB
27-12-2013 4:36 PM
I moderate on z22se.co.uk now
Re: Capped @ 66.5MB
27-12-2013 4:37 PM
Re: Capped @ 66.5MB
27-12-2013 4:47 PM
Re: Capped @ 66.5MB
27-12-2013 5:13 PM
27-12-2013 6:46 PM
never seen it called an EWAN port before today?
Ian
27-12-2013 6:50 PM
