7800N Firmware
- 7800N Firmware
7800N Firmware
07-04-2012 10:52 AM
Sorry about the thread hijack, but I have another question for Strat;
Is it worthwhile updating the 7800N to 1.06f firmware? The firmware itself has got a half a star out of 5 rating on Billion's UK website, which is a little off-putting to say the least!
dick:green Post split off to new topic and retitled.
Message 1 of 8
(3,439 Views)
7 REPLIES 7
Re: 7800N Firmware
07-04-2012 1:29 PM
Probably not but I haven't had chance to see what has changed yet......if anything
My sync rate crept up from 8000Kbs to 8128Kbs (before an overnight resync dropped it back to 8096Kbs) but I don't know if the firmware update had anything to do with it.
Message 2 of 8
(688 Views)
Re: 7800N Firmware
07-04-2012 1:55 PM
Can't see much of any real relevance.
Message 3 of 8
(688 Views)
Re: 7800N Firmware
07-04-2012 4:25 PM
Sorry to but in..
Everytime I try to upgrade my router with this firmware it does not do anything whatsoever... After clicking "upgrade" I have the "waiting for 192.168.1.254" forever, just wondering what im doing wrong if anything?
Message 4 of 8
(688 Views)
Re: 7800N Firmware
08-04-2012 9:59 AM
I have got a 7800N on 1.06d firmware which kept losing the connection to Plusnet. Plusnet decided it was a router problem and so I reinstated my linksys wag200g and that is working OK. I was also wondering if it was worth trying the 1.06f firmware. The 1.06e firmware wasn't rated highly so that doesn't bode well either.
Message 5 of 8
(688 Views)
Re: 7800N Firmware
08-04-2012 10:45 AM
Quote from: cjags I was also wondering if it was worth trying the 1.06f firmware. The 1.06e firmware wasn't rated highly so that doesn't bode well either.
Neither the 1.06e or 1.06f release notes have anything that seems relevant to your issues, but I'm on 1.06e without any connection issues so I guess it might be worth a shot...
@ Steek - where did you get the 1.06f firmware from? I guess it might be worth double checking that it's from the UK site and that it has the .afw extension... (and is definitely for the 7800N and not the 7800)
I'll probably try updating mine later on even though it's currently working fine... I have this weird obsession with my software always having to be bang up to date
Message 6 of 8
(688 Views)
Re: 7800N Firmware
08-04-2012 2:27 PM
Hey, yes its from the UK website and it has the .afw extension.. Everytime I try it I have to reset my router and never works so I may just leave it. Thanks for your help though.
Message 7 of 8
(688 Views)
Re: 7800N Firmware
22-04-2012 12:50 PM
For info, firmware 1.06g is now available for test. Seems to be going ok and fixes some problems with 1.06f.
http://www.billion.uk.com/forum/viewtopic.php?f=16&t=356
Message 8 of 8
(688 Views)
