70 mbps Wired, 30-40 mbps (Beside Router) Wireless
- 70 mbps Wired, 30-40 mbps (Beside Router) Wireless
- « Previous
- 1
- 2
- Next »
Re: 70 mbps Wired, 30-40 mbps (Beside Router) Wireless
27-09-2012 11:46 AM
27-09-2012 11:52 AM
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
27-09-2012 11:56 AM
27-09-2012 4:12 PM
27-09-2012 4:41 PM
27-09-2012 5:31 PM
27-09-2012 6:21 PM
29-09-2012 4:22 PM
29-09-2012 4:33 PM
29-09-2012 4:51 PM
02-10-2012 3:41 PM
I have the ASUS N66U here now. Up close, I was getting into high 60's mbps but now the router is just outside the next room, that's dropped to 20-30mbps. O on wired, I get 70mbps +. This router has 3 antennas and is transmitting at full power on 2.4Ghz. I have set it to wireless N only mode and tried several different channels (I used inSSIDer to select channels no one else is using). I also disconnected the cordless phone. I am using wireless now and doing speedtests nd they can range as low as 12mbps to as high as 58mbps. It's odd. I will try a few more things then I think it's time to try these homeplugs.
EDIT: Just tried the router on wireless upstairs on a different PC and it works at full speed @ 70mbps. It's on the downstairs PC that it slows down to 20-30 but sometimes the speed does go to over 50. I will have to investigate this further.
I now have the wireless working at full speed on the PC I wanted it on. I ran speedtests all around the home using my USB adapter and a laptop. I noticed towards the back of the house, the speed drops by half. My PC is at the back of the house, but I have found a spot that enables me to run at full speed. I received a Plusnet USB adapter, and this runs on par with my own adapter.
- « Previous
- 1
- 2
- Next »
