6417/319 but browsing through treacle!
- Re: 6417/319 but browsing through treacle!
26-08-2009 8:21 PM
The figures in the subject are at 8pm and I think they look pretty good but when I am browsing the web it seems to take a long time to load each page. Almost as if it has to think about it before it loads. I have disabled firewall and AV but it makes no difference. I am sure this has been creeping on for the lat couple of months. I have rebooted the router (Speedtouch) but it makes no difference.
PT
27-08-2009 12:04 PM
Is there any chance you could show us what a traceroute looks like when you're seeing these problems?
27-08-2009 2:49 PM
Quote from: Jameseh Hiya,
Maybe, if you give me a clue how to get one!
Jon
27-08-2009 3:13 PM
In XP and Vista it is relatively easy. Click on the start menu button and select “Run” then type CMD and then press the Enter key. This will open a DOS window.
In Windows 7 it is more difficult as the Run command is hidden by default. The easy way out of this is to right click on the desktop, select “New” then “Shortcut” and type or paste this in the location box “C:\Windows\System32\cmd.exe” without the quotation marks assuming that Windows is installed in the C: Drive. This shortcut will then open a DOS window.
In the DOS window type "tracert bbc.co.uk" without the quotation marks then hit enter
One it has finished right click with the mouse and click on select all. The text will then change from white on black to black on white. Pressing return on the keyboard will add the text to the clipboard and then you can past it into your post
27-08-2009 3:18 PM
Could it be a problem with a gateway or load balancer?
traceroute (using linux) below:
nigel@nigel-main:~$ traceroute www.bbc.co.uk
traceroute to www.bbc.co.uk (212.58.251.195), 30 hops max, 40 byte packets
1 * * *
2 lo0-plusnet.ptn-ag2.plus.net (195.166.128.53) 12.679 ms 19.530 ms 22.996 ms
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
nigel@nigel-main:~$ traceroute www.plus.net
traceroute to www.plus.net (212.159.9.2), 30 hops max, 40 byte packets
1 * * *
2 lo0-plusnet.ptn-ag2.plus.net (195.166.128.53) 11.629 ms 12.663 ms 14.130 ms
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * fhw-lb04.plus.net (212.159.1.146) 24.722 ms
Nigel
27-08-2009 3:20 PM
Can you try rebooting your router please?
27-08-2009 3:28 PM
traceroute to www.bbc.co.uk (212.58.253.67), 30 hops max, 40 byte packets
1 * * *
2 lo0-plusnet.thn-ag3.plus.net (195.166.128.80) 10.996 ms 17.206 ms 18.098 ms
3 vl303.thn-gw1.plus.net (84.92.3.177) 16.355 ms 18.008 ms 19.297 ms
4 te2-3.thn-gw2.plus.net (212.159.1.58) 22.492 ms 23.234 ms 25.396 ms
5 rt0.thdo.bbc.co.uk (212.58.239.25) 70.494 ms 71.342 ms 71.378 ms
6 212.58.238.133 (212.58.238.133) 32.722 ms 23.848 ms 21.173 ms
7 te12-1.hsw0.cwwtf.bbc.co.uk (212.58.239.222) 22.127 ms 23.680 ms 25.397 ms
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
1 * * *
2 lo0-plusnet.thn-ag3.plus.net (195.166.128.80) 11.015 ms 12.443 ms 14.154 ms
3 vl303.thn-gw1.plus.net (84.92.3.177) 16.633 ms 17.564 ms 19.995 ms
4 te2-3.thn-gw2.plus.net (212.159.1.58) 21.244 ms 23.920 ms 25.636 ms
5 vl23.pte-gw2.plus.net (212.159.4.28) 26.922 ms 29.789 ms 31.018 ms
6 92.core.plus.net (212.159.1.92) 39.682 ms 30.469 ms 30.516 ms
7 fhw-lb04.plus.net (212.159.1.146) 66.811 ms 65.163 ms 65.504 ms
8 fhw-lb04.plus.net (212.159.1.146) 65.026 ms 64.685 ms 62.245 ms
Nigel
27-08-2009 3:30 PM
27-08-2009 3:38 PM
traceroute to bbc.co.uk (212.58.224.138), 30 hops max, 40 byte packets
1 * * *
2 lo0-plusnet.thn-ag3.plus.net (195.166.128.80) 15.551 ms 15.668 ms 15.728 ms
3 vl303.thn-gw2.plus.net (84.92.3.178) 29.304 ms 30.524 ms 30.648 ms
4 rt0.thdo.bbc.co.uk (212.58.239.25) 30.686 ms 30.969 ms 31.094 ms
5 212.58.238.133 (212.58.238.133) 31.140 ms 31.609 ms 33.550 ms
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Nigel
27-08-2009 4:50 PM
01-09-2009 8:38 PM
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Jon>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
1 28 ms 99 ms 99 ms speedtouch.lan [192.168.1.254]
2 45 ms 57 ms 65 ms lo0-plusnet.pcl-ag04.plus.net [195.166.128.134]
3 98 ms 202 ms 206 ms gi1-6-604.pcl-gw02.plus.net [84.92.0.229]
4 135 ms 216 ms 47 ms te2-2.thn-gw2.plus.net [212.159.0.190]
5 202 ms 200 ms 103 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 36 ms 37 ms 45 ms 212.58.238.133
7 35 ms 37 ms 37 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
There you go. Its pretty sluggish now.
Jon
02-09-2009 9:16 AM
Hop one is my router, otherwise that's it to bbc.co.uk
1 <1 ms <1 ms <
2 32 ms 32 ms 34 ms lo0-plusnet.pcl-ag03.plus.net [195.166.128.109]
3 29 ms 29 ms 30 ms gi1-6-703.pcl-gw01.plus.net [84.92.0.181]
4 74 ms 206 ms 204 ms te2-1.pcl-gw02.plus.net [212.159.1.114]
5 30 ms 29 ms 31 ms te2-2.thn-gw2.plus.net [212.159.0.190]
6 31 ms 31 ms 30 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 30 ms 30 ms 31 ms 212.58.238.133
8 30 ms 30 ms 30 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
1 <1 ms <1 ms <
2 31 ms 31 ms 30 ms lo0-plusnet.pcl-ag03.plus.net [195.166.128.109]
3 30 ms 30 ms 30 ms gi1-6-703.pcl-gw01.plus.net [84.92.0.181]
4 30 ms 30 ms 31 ms te2-1.pcl-gw02.plus.net [212.159.1.114]
5 30 ms 30 ms 30 ms te2-2.thn-gw2.plus.net [212.159.0.190]
6 30 ms 29 ms 31 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 30 ms 29 ms 30 ms 212.58.238.133
8 30 ms 30 ms 29 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
1 2 ms <1 ms <
2 30 ms 192 ms 165 ms lo0-plusnet.pcl-ag03.plus.net [195.166.128.109]
3 79 ms 216 ms 222 ms gi1-6-703.pcl-gw01.plus.net [84.92.0.181]
4 30 ms 30 ms 29 ms te2-1.pcl-gw02.plus.net [212.159.1.114]
5 30 ms 29 ms 30 ms te2-2.thn-gw2.plus.net [212.159.0.190]
6 31 ms 31 ms 31 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 30 ms 30 ms 30 ms 212.58.238.133
8 31 ms 30 ms 30 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
03-09-2009 5:44 PM
Quote from: PhyllisTyne Microsoft Windows [Version 6.0.6002]
Trace complete.
Jon
Does this indicate a problem somewhere?
Jon
03-09-2009 5:58 PM
and my browsing is OK
Quote Tracing route to bbc.co.uk [212.58.224.138]
1 <1 ms <1 ms <1 ms 192.168.0.1
2 42 ms 37 ms 36 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 37 ms 39 ms 38 ms ge0-0-0-504.pte-gw2.plus.net [84.92.4.90]
4 37 ms 38 ms 37 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 102 ms 111 ms 134 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 40 ms 36 ms 38 ms 212.58.238.149
7 37 ms 36 ms 37 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
03-09-2009 7:27 PM
Quote Reply from 84.92.0.229: bytes=32 time=17ms TTL=252
Reply from 84.92.0.229: bytes=32 time=16ms TTL=252
Reply from 84.92.0.229: bytes=32 time=20ms TTL=252
Reply from 84.92.0.229: bytes=32 time=23ms TTL=252
Reply from 84.92.0.229: bytes=32 time=113ms TTL=252
Reply from 84.92.0.229: bytes=32 time=138ms TTL=252
Reply from 84.92.0.229: bytes=32 time=179ms TTL=252
Reply from 84.92.0.229: bytes=32 time=212ms TTL=252
Reply from 84.92.0.229: bytes=32 time=42ms TTL=252
Reply from 84.92.0.229: bytes=32 time=66ms TTL=252
Ping statistics for 84.92.0.229:
Packets: Sent = 65, Received = 65, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 16ms, Maximum = 212ms, Average = 27ms
