6 routers and counting
- 6 routers and counting
- « Previous
- 1
- 2
- Next »
Re: 6 routers and counting
09-05-2013 1:30 AM
Hi
The d-link does not show CRC errors in its statistics log only HEC errors,and the phone is plugged into the master socket,The router is on 24/7 and i dont have any other phone sockets in the house and no phone extensions, the router is less than 1ft away from master socket as for the plusnet routers they are the technicolor and TG582n..I did a tracert just before i logged onto this ill post with this....Finnigan
Message 16 of 22
(411 Views)
09-05-2013 1:33 AM
Heres the tracert
Message 17 of 22
(411 Views)
09-05-2013 10:34 AM
OK, if you are seeing no further/other problems with you connection and are happy with the error rate, ask for Interleaving to be turned off.
Just post back here saying so, and a member of the DCT will most likely do it for you.
Message 18 of 22
(411 Views)
09-05-2013 11:57 AM
Hi Anotherone
Thanks for all your help, and so far i have not seen any other errors and would like the interleaving turned off, TBH i have had no other issues untill recently and i think the package you get from Plusnet adsl and phone is the best out there!!!! Many thanks again Anotherone.....Finnigan
Message 19 of 22
(411 Views)
09-05-2013 12:54 PM
Just placed the order to remove interleaving for you, that'll complete tomorrow morning Hope it improves things.
Message 20 of 22
(411 Views)
09-05-2013 1:28 PM
Hi Matt
Thanks for the reply, thanks for placing the order to remove interleaving!!!!!!....Finnigan
Message 21 of 22
(411 Views)
13-05-2013 3:27 PM
Message 22 of 22
(411 Views)
- « Previous
- 1
- 2
- Next »
