5mb down/20mb up after installation
- Re: 5mb down/20mb up after installation
24-10-2013 11:32 AM
I just had FTTC installed and I am getting 5mb download. The checker thingie says:
Estimated line speed:
59Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-10-17 14:34:03
Current line speed:
78 Mb
Is this normal?
24-10-2013 11:35 AM
Your account profile is set correctly, could you run a speedtest at http://speedtest.btwholesale.com and run further diagnostics post your results?
24-10-2013 11:38 AM
Further diagnostics says:
No Fibre to the Premises (FTTP) services have been found at this address. Please check the postcode or use the Telephone Number or Service ID to conduct the test.
Click here to try again.
24-10-2013 11:41 AM
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
24-10-2013 11:59 AM
24-10-2013 1:28 PM
24-10-2013 2:18 PM
24-10-2013 2:22 PM
24-10-2013 2:52 PM
For your wireless you could try changing your wireless channel, a guide can be found here.
Are the devices your're trying to connect wireless with wireless N do you know?
24-10-2013 3:50 PM
24-10-2013 4:10 PM
24-10-2013 4:12 PM
24-10-2013 5:52 PM
W23: Thanks. Which of the tweaks could help me speed up the wireless connection?
24-10-2013 6:38 PM
24-10-2013 8:43 PM
Quote from: aurys I have enabled N mode on my card and changed the wireless channel, it is now maxing at 35Mb. Still quite low when compared to the 60 that I get through wired, would ideally like to get more.
Are you able to see what connection speed the wireless card is reporting.
Not all wireless N cards have the same capabltiies.
