5ghz devices not connecting to each other.
wilfy33
i have hub-one router that i'm not sure what is going on.  I've recently fired up home assistant on a laptop that i'm testing using it's built in wifi. This is connecting to the 5ghz band on my router. I have set a static ip for this.
When my android phone connects to 5ghz i cannot get a connection to the home assistant web page on this laptop.
If i change my phone to 2.4ghz , it connects fine.
If i use my desk top - ethernet connected, the web page is fine.
Any ideas ?
Thx
3 REPLIES 3
HPsauce
Seasoned Pro
Fixes: 5
Re: 5ghz devices not connecting to each other.
Are the two bands using the same name, that can cause confusion? If they are try giving the 5GHz band a different name, that's one useful feature of Hub One missing in Hub Two.
wilfy33
HP sauce - yes they are. Never had to consider splitting the 2 bands before.
Changed 5ghz wifi ssid and now it's working.
I get a broadband drop out at least once a day, so i'll make sure it's all still working after a reset.
Fixes: 334
That suggests you have a broadband issue, which needs looking at.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one the only option is to call Plusnet - 0330 123 9123
