585v8
- 585v8
585v8
585v8
12-09-2011 9:28 AM
i know reading on the forum they give incorrect error counts, but i have the problem of regular disconects from game servers now , which i didnt have with the HH2
is it possible my 585v8 is naff or is it just normal
Re: 585v8
Re: 585v8
12-09-2011 9:31 AM
This may be due to the weather or that the 585 isn't as good as the homehub on a noisy line - I also note that your line is interleaved which isn't good for gaming
One point - and it may be a reporting glitch - most of your errors are on the upstream feed
Re: 585v8
Re: 585v8
12-09-2011 11:19 AM
Besides those stats how is your connection performing? what are the speeds like?
Quote i was forced to connect with the 585v8
No one's forcing you, the homehub probablyt won't work but you can choose your own hardware....
Adam Walker Plusnet Help Team |
Re: 585v8
Re: 585v8
12-09-2011 4:45 PM
hence it went pop
the connection speed is fine its just i am getting high ping spikes again
Re: 585v8
Re: 585v8
13-09-2011 5:30 PM
Re: 585v8
Re: 585v8
13-09-2011 6:05 PM
Re: 585v8
Re: 585v8
13-09-2011 6:33 PM
Re: 585v8
Re: 585v8
14-09-2011 4:40 PM
Re: 585v8
Re: 585v8
16-09-2011 1:47 PM
Re: 585v8
Re: 585v8
16-09-2011 1:53 PM
Re: 585v8
Re: 585v8
18-09-2011 5:42 PM
errors are less tho
any idea,s adam ?
Re: 585v8
Re: 585v8
19-09-2011 10:19 AM
Re: 585v8
Re: 585v8
19-09-2011 10:52 AM
i would love to know why ? do they fit you a new master socket BT, if then you have to remove part to get a good connection
i have fitted the new filters which came with the new router , only 1 phone and no extensions .
BT cable from my house was renewed when i joined PN oct last year
Re: 585v8
Re: 585v8
19-09-2011 11:08 AM
Re: 585v8
Re: 585v8
19-09-2011 12:25 PM
its just the annoying ping spikes
