585 v8 firmware
- 585 v8 firmware
Re: 585 v8 firmware
15-11-2011 1:58 PM
I wasn't sure if my profile might be stuck or whether I just needed a bit more patience. I did (unsuccessfully) attempt a BT Speedtest shortly before posting earlier (about 7.30 a.m). I've just tried again, and I'm getting exactly the same error message:
Test Error
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Re: 585 v8 firmware
15-11-2011 5:03 PM
Re: 585 v8 firmware
15-11-2011 10:22 PM
Re: 585 v8 firmware
16-11-2011 7:52 AM
(note to mods)
Seems my contribution to this topic is now gradually shifting emphasis away from firmware related considerations. Maybe it would be best if a new moved topic could be started from Reply 13 with a title like
"Stuck with 20CN profile after 21CN migration"
Re: 585 v8 firmware
16-11-2011 1:21 PM
Re: 585 v8 firmware
16-11-2011 3:38 PM
The Plusnet "Current line speed" profile doesn't feed back to BT, but if set below the BT IP Profile value will reduce measured download speeds.
I would be inclined to try restarting the router (once) via the "Restart my Thomson Gateway" task on the Thomson Gateway page to see if that prompts the DLM into increasing your IP Profile. Now that you are on 21CN the BT IP Profile should be 88.2% of your sync speed.
Re: 585 v8 firmware
16-11-2011 3:51 PM
Quote from: spraxyt I would be inclined to try restarting the router (once) via the "Restart my Thomson Gateway" task on the Thomson Gateway page to see if that prompts the DLM into increasing your IP Profile.
I've been pondering about that - but kid gloves go hand in hand with my trial. So I thought I'd wait for an official response first, in case the problem is identifiable (and fixable) by BT or Plusnet.
Re: 585 v8 firmware
16-11-2011 8:48 PM
I've just tried running some diagnostics but it wouldn't let me go too far without telling me that you were in the stabilisation (training) period. I'll have a word with one of the faults guys tomorrow and see if they can come up with any ideas.
Jojo
Re: 585 v8 firmware
16-11-2011 10:35 PM
To reinforce my last comment....I don't think I've EVER had occasion to reboot my router since the day it was first plugged in. That's partly why I was/am reluctant to choose the start of a training period for introducing such rare behaviour. I do find my router's reporting of zero output power a bit odd, but I'll continue to wait and see if you can find an alternative to asking me to reboot (incidentally although the router's linestats continue to report zero down power, I did notice later that the (linestate up) event logged at the start of the connection stated Power Down: 21.0 dBm. Since then the only events logged have been regular syncs every hour.
Nov 15 04:15:59 xDSL linestate up (ITU-T G.992.5; downstream: 18203 kbit/s, upstream: 1195 kbit/s; output Power Down: 21.0 dBm, Up: 12.0 dBm; line Attenuation Down: 20.0 dB, Up: 9.5 dB; snr Margin Down: 6.0 dB, Up: 7.5 dB)
I'm well into my second day now, and on a positive note the connection has remained very stable (albeit with a 20CN profile). With the lower SN margins my error count has increased a bit from the paucity I used to get. But the error count is still quite low so I'm hoping that might augur well for a much faster but still very reliable connection? ....eventually
Link Information
Uptime: 1 day, 17:36:23
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,195 / 18,203
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 9.5 / 20.0
SN Margin (Up/Down) []: 6.5 / 6.0
Loss of Framing (Local/Remote): 155 / 0
Loss of Signal (Local/Remote): 35 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 59 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 208
HEC Errors (Up/Down): 0 / 148
Re: 585 v8 firmware
17-11-2011 8:13 AM
Yes, it does look like you'll get a good speed. I only wish I could do something now, but like I said last night, I'll have a word with one of the faults guys and see what they can come up with.
Jojo
Re: 585 v8 firmware
17-11-2011 10:49 AM
Looks like it's changed now, I'll change it on our side. Let me know what you're seeing on a BT Speed test now.
Jojo
Re: 585 v8 firmware
17-11-2011 12:06 PM
My BT profile is now 16060Kbps which is indeed 88.2% of my 18203Kbps sync, whilst my Plusnet current line speed is now 15 Mb.
I've also noticed that I started a new PPP internet connection at 11.01 a.m. (twixt your last post and my new fast 11.15 a.m. BT Speedtest). I'm very grateful indeed for whatever buttons you might have pressed or contact you've made with others on my behalf to get things moving.
Cheers!
Re: 585 v8 firmware
17-11-2011 3:11 PM
Re: 585 v8 firmware
17-11-2011 5:01 PM
Yet again my router seems to have started another PPP internet connection shortly after your post (at 15:15). Please tell me this is normal behaviour related to manual changes of my profile rather than any drops in connection that might be more worrying during this training period
Re: 585 v8 firmware
17-11-2011 5:22 PM
