585 v8 SNMP Support
- Re: 585 v8 SNMP Support
585 v8 SNMP Support
29-09-2011 10:57 AM
HI,
I was just wondering if my 585v8 supported snmp?
I'd like to see if i can get it running, but if my router doesn't support it, its not worth setting the kit up to find out!
I've read other posts on the net that says it might be been turned off in a software upgrade.
But as plusnet manage there own code i thought it was worth asking.
Pete
Pete
Message 1 of 2
(623 Views)
1 REPLY 1
29-09-2011 11:12 AM
Hi Pete,
Not 100% sure it works on the v8 although I think it did on the v7. Worth looking here though and giving it a try.
Jojo
Jojo
Message 2 of 2
(313 Views)
