582n and port forwarding
- 582n and port forwarding
04-03-2013 12:09 PM
Hopefully I'm missing something obvious here...
I used to have adsl with a speedtouch 585. I had port 80 forwarded to a web server on my network - it all worked externally. I've previously had mail and ftp forwarded as well, so I thought I knew what I was doing
I'm now on fibre with a technicolor 582n. The port forwarding UI looks exactly the same ("game and app sharing"). I've got port 80 forwarded to the same machine yet it doesn't work externally.
I may well have turned the firewall off on the 585 but I don't really want to have to do that now. I only want to forward the one port to the webserver.
Any guesses as to what I've not done?
Thanks,
Ric
Thanks,
Ric
Message 1 of 4
(756 Views)
3 REPLIES 3
Re: 582n and port forwarding
04-03-2013 12:17 PM
These 582's are notorious for NOT forwarding the ports you ask for. If you search on here you will find MANY people with the same issues.
Message 2 of 4
(385 Views)
04-03-2013 12:22 PM
hmmm, useful
has anyone had any luck getting it to behave?
Message 3 of 4
(385 Views)
04-03-2013 10:32 PM
ok, my mistake... didn't notice that the service i have running on there doesn't run on port 80....
Message 4 of 4
(385 Views)
