582n Firmware version
- 582n Firmware version
02-12-2012 9:29 PM
My Plusnet supplied 582n is running the 8.4.4.I version of the firmware.
I have found versions 8.4.4.J and R10.2.1.8 on the Plusnet website.
What are the benefits of the upgrades? Would it be prudent to upgrade and why might I pick one version rather than the other?
Message 1 of 6
(1,174 Views)
5 REPLIES 5
Re: 582n Firmware version
02-12-2012 11:37 PM
I suspect the R10.2.1.8 is for the ADSL version of the router and 8.4.4.J is for the fibre version which i guess you are on from your firmware
I am current on 8.C.M.0 which i got last month when upgrading to fibre, maybe you could ask the PN staff for that version as i would think that is the current one they are shipping out.
Message 2 of 6
(542 Views)
03-12-2012 12:37 AM
8.4.4.J is on mine so not for fibre, guessing its just the beta version number they use
FTTP 500 regrade from Tues 28th November
Message 3 of 6
(542 Views)
03-12-2012 1:43 AM
Does the 8.4.4.J version support a USB printer? BE appear to have a version that does that.
I suspect that the R10 version has IPV6
Message 4 of 6
(542 Views)
03-12-2012 4:23 AM
Mine doesn't have a USB port and no USB options with its web interface, so no
Message 5 of 6
(542 Views)
03-12-2012 3:14 PM
Mine has a port and the CLI accepts printersharing commands.
So far I have not got it to print though!
Message 6 of 6
(542 Views)
