5 hour outage
HaresEar
5 hour outage
My Broadband was down in LA4 last night for 5 hours.  What caused that.  It took 30mins for technical support to answer. Told there is a problem in the area.
Fixes: 62
Re: 5 hour outage
try putting your number in http://status.zen.co.uk/broadband/
Fixes: 21
Re: 5 hour outage
If it wasn't a fault it might have been http://usertools.plus.net/status/archive/1407760912.htm ; Note the first paragraph after the listing.
HaresEar
Re: 5 hour outage
Thanks but not listed so must have been a fault. Officially according to tech support Problem in are from 18:45 to be cleared by 11:30. My hub reported connection was made at 01:06 next day.
Fixes: 21
Re: 5 hour outage
You could try http://usertools.plus.net/exchanges/ - on your exchange page, click the 'here' on the 3rd line. That is usually updated regularly, but the rest of the data isn't at the moment.
