5 hour outage
- Re: 5 hour outage
5 hour outage
15-08-2014 6:35 PM
My Broadband was down in LA4 last night for 5 hours. What caused that. It took 30mins for technical support to answer. Told there is a problem in the area.
Message 1 of 5
(737 Views)
4 REPLIES 4
Re: 5 hour outage
15-08-2014 6:45 PM
try putting your number in http://status.zen.co.uk/broadband/
Message 2 of 5
(470 Views)
Re: 5 hour outage
15-08-2014 7:29 PM
If it wasn't a fault it might have been http://usertools.plus.net/status/archive/1407760912.htm ; Note the first paragraph after the listing.
Message 3 of 5
(470 Views)
Re: 5 hour outage
15-08-2014 9:03 PM
Thanks but not listed so must have been a fault. Officially according to tech support Problem in are from 18:45 to be cleared by 11:30. My hub reported connection was made at 01:06 next day.
Message 4 of 5
(470 Views)
Re: 5 hour outage
15-08-2014 9:09 PM
You could try http://usertools.plus.net/exchanges/ - on your exchange page, click the 'here' on the 3rd line. That is usually updated regularly, but the rest of the data isn't at the moment.
Message 5 of 5
(470 Views)
