5 days no phone
jono
Fixes: 7
5 days no phone
Hi, ive had a problem with my phone line which is now fixed, had bt engineer out today.
I've checked online with my account and my speed was 21mb now its just over 11mbps, will it automatically put itself right or will customer service have to reset something?
15 REPLIES 15
MatthewWheeler
Fixes: 479
Re: 5 days no phone
Our tests are still showing your sync speeds as 24mbps so you should be getting better speeds.
Have you tried disconnecting and reconnecting your PPP session?
 Matthew Wheeler
jono
Fixes: 7
Re: 5 days no phone
Hi, thanks for the quick reply, not sure what you mean by reset ppp
Regards
Jono
jono
Fixes: 7
Re: 5 days no phone
Hi Just checked estimated line speed its gone form 21 to
Estimated line speed:
Current line speed:
11.6 Mb
The wires on the main socket were causing all sorts of crackling on line and permanently engaged
jono
Anoush
Aspiring Hero
Fixes: 139
Re: 5 days no phone
Hey there. I've adjusted your connection profile now, if you reboot your router you should see a faster speed.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
jono
Fixes: 7
Re: 5 days no phone
Hi Anoush, Thanks for that, yes my download speed is back to normal but ( theirs always a but) my upload speed is down to a third of what is normal for me, I've done some tests and im putting results here for you, I don't know if this is a problem at the moment but I'm finding web pages taking an age to load and getting time outs a lot as well.
If you need any more information please let me know and I'll send what is necessary
8/31/2016 1:05 PM GMT 51.7.146.217 19.99 Mb/s 0.38 Mb/s 27 ms Newcastle upon Tyne < 50 mi Share
8/31/2016 1:03 PM GMT 51.7.146.217 20.94 Mb/s 0.36 Mb/s 27 ms Newcastle upon Tyne < 50 mi Share
8/31/2016 1:01 PM GMT 51.7.146.217 20.79 Mb/s 0.38 Mb/s 27 ms Newcastle upon Tyne < 50 mi Share
8/30/2016 5:40 PM GMT 194.75.91.182 20.38 Mb/s 0.35 Mb/s 20 ms London < 50 mi Share
8/30/2016 5:12 PM GMT 51.7.148.116 18.28 Mb/s 0.39 Mb/s 24 ms York ~ 50 mi Share
8/24/2016 6:33 PM GMT 51.7.146.6 20.93 Mb/s 0.98 Mb/s 25 ms Newcastle upon Tyne < 50 mi Share
8/17/2016 6:07 PM GMT 51.7.147.130 20.93 Mb/s 1.00 Mb/s 24 ms Newcastle upon Tyne < 50 mi Share
8/17/2016 6:05 PM GMT 51.7.147.130 20.91 Mb/s 0.94 Mb/s 26 ms Newcastle upon Tyne < 50 mi Share
As you can see i usually have at least 1mbps upload
regards
Jono
jono
Fixes: 7
Re: 5 days no phone
just thought I'd add a note, its like wading through treacle, im trying to sort pet insurance and all I'm getting is timed out or taking ages to load pages.I'm supposed to be on the new plus net gateway which should be better
regards
Jono
jono
Fixes: 7
Re: 5 days no phone
Hi anoush, Me again ,been looking at router stats and noticed this
Uptime: 0 days, 2:34:13
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 24,382
Data Transferred (Sent/Received) [MB/MB]: 15.30 / 259.04
Output Power (Up/Down) [dBm]: 11.4 / 0.0
Line Attenuation (Up/Down) [dB]: 1.9 / 4.5
SN Margin (Up/Down) [dB]: 34.1 / 3.3
Loss of Link (Remote): -
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
regards
Jono
MatthewWheeler
Fixes: 479
Re: 5 days no phone
It looks like your upload has been capped which is why the SNR margin is so high on your upload.
I'm just looking at this for you.
 Matthew Wheeler
jono
Fixes: 7
Re: 5 days no phone
Hi, Just wondering whats happening Mathew, should I raise a ticket about this problem? The problem with the main BT socket was two wires were degraded and touching so I had no dialing tone bad interference and permanent  engaged tone when someone tried to phone in. It had this problem for 5 days, hence the trouble I'm experiencing now.
If I need to raise a ticket could you let me know and I'll do so as soon as possible
regards
jono
MatthewWheeler
Fixes: 479
Re: 5 days no phone
I've put through a line reset which should sort this out.
 Matthew Wheeler
jono
Fixes: 7
Re: 5 days no phone
Thanks very much hope it gets me back to normal, been one of those weeks, somebody took paint of my car in car park yesterday
Regards
Jono
MatthewWheeler
Fixes: 479
Re: 5 days no phone
Let us know if you're still having issues.
 Matthew Wheeler
jono
Fixes: 7
Re: 5 days no phone
Ok will do, do i need to reboot router or leave alone for few days?
Jono
MatthewWheeler
Fixes: 479
Re: 5 days no phone
You shouldn't have to do anything.
 Matthew Wheeler
