4hr connection loss & line speed drop
- 4hr connection loss & line speed drop
25-04-2013 10:51 AM
My connection went down at 05:13 and came back up at 09:39 since which my line speed has dropped from 21Mb to 18Mb and a 16.1 ip profile down from 18.xx.
I know DLM is still running on the line and on Tuesday we put in an order to have interleaving removed, but is it normal for the line speed to change like this and have such long disconnections?
I'm used to seeing a stable line that syncs at 24,574 with BE so this is a little deflating ATM.
Message 1 of 6
(974 Views)
5 REPLIES 5
Re: 4hr connection loss & line speed drop
25-04-2013 11:41 AM
It looks like your disconnection this morning was caused by planned maintenance although for some reason it seems you haven't automatically reconnected straight away as normally would happen.
I can't see any obvious reason for the speed change although your line is still in it's 10 day training period where you can see speed fluctuation.
Message 2 of 6
(492 Views)
25-04-2013 11:53 AM
Thanks for the reply,
I saw that but as it was expected to take up-to 1 hour and that users may experience a brief disconnection, I kind of discounted it having been disconnected for 4 1/2 hours myself.
TBH I'm a little worried about this line speed as I thought the line speed was the maximum the line could handle dependent on physical characteristics such as condition of the line and ISP's equipment, with any software limiting/ configurations being elected in the IP profile.
If after the 10 day period is up and my sync is less than 24,574 I know that either there is something up with Plusnets configuration or their equipment as this drop occurred immediately upon migration, but obviously we will have to wait a few days before getting into that if we need to.
Quote Possibly. All users connected to the gateway known as PTW-AG01 will be briefly disconnected from the Internet. Those disconnected should be able to reconnect almost immediately.
Message 3 of 6
(492 Views)
25-04-2013 1:53 PM
Let me know what it like after your 10 day training period ends(this is from the start of your ADSL service) and I'll check again and go from there.
Message 4 of 6
(492 Views)
25-04-2013 7:54 PM
Yeh I'm just being pessimistically impatient as usual I suppose, plus I'm yet to be convinced that DLM is actually a good thing on my line.
Message 5 of 6
(492 Views)
12-05-2013 10:09 AM
FYI Plusnet has no direct control over your sync speed. That will be entirely down to the condition & length of, and any interference/noise picked up by, your line.
Message 6 of 6
(492 Views)
