44Kbps from 20MB service
- 44Kbps from 20MB service
Re: 44Kbps from 20MB service
17-06-2010 3:42 PM
17-06-2010 3:51 PM
Just a few things
1. You would not lose your service at all...not even for a few days!
2. The 72 hour period is inflexible
3. Of course the engineer can check the line
4. Sorry you were misinformed, I shall be feeding back the advisers details for this.
5. Hope all is well after the 72 hours
17-06-2010 3:59 PM
I wish all the Plusnet advisors would sing from the same hymn sheet. When you get so much contradictory advice, you start suspecting everything they say.
Having said that, most of the support guys we've talked to have been very pleasant and helpful, and it can't be an easy job.
Thanks for confirming the 72-hour thing.
17-06-2010 4:04 PM
18-06-2010 5:41 PM
21-06-2010 7:38 AM
21-06-2010 9:43 AM
Things are looking a bit better as your ip profile has now moved up to 350k, this will continue to increase the longer your connection is stable.
Jojo
21-06-2010 4:49 PM
Oh dearie me, I thought to myself (or words to that effect). The Plusnet adviser said he would post his record of the disconnects on our ticket, and we said we would do the same so that the Faults Team could see for themselves. We have now posted our info on the ticket but the Plusnet adviser hasn't. He's had over an hour to do it now - so I guess he just couldn't be bothered.
We are now sitting here wondering what's going on.
Here is the data showing that we have been up for over 72 hours without a dropout or error. Do any of the Plusnet people on this forum have any leverage to get something done here?
21-06-2010 5:13 PM
Sorry for the delay, I have been carrying out some tests and I have now raised this to BT. We'll get back to you as soon as we get any more information.
Jojo
21-06-2010 5:21 PM
I assume that 'raised to BT' means that there is a problem at the exchange that BT needs to fix. Can you give me some idea of timescale here?
21-06-2010 5:29 PM
Quote I assume that 'raised to BT' means that there is a problem at the exchange that BT needs to fix
It means BT have been made aware you are having an issue, they will (or should) check the exchange, phoneline, and if there is no issue here, the connection from the actual line to the socket in your house (e.g. is there a wiring fault in your house, which is their problem)
Also, testing could cause dropouts, especially if they do something like a linecard reset (think rebooting )
21-06-2010 5:40 PM
22-06-2010 9:32 AM
Download speed achieved during the test was - 199 Kbps
For your connection, the acceptable range of speedsis 2000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :15428 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 13000 Kbps
Could someone pull a lever somewhere?
22-06-2010 10:51 AM
having raised it to BT yesterday, they sent it back to us cleared so I have re-escalated it to them as not resolved.
22-06-2010 11:09 AM
