44 days no broadband is this a new record
Povvercrazy
Hi
I reported a fault to Plusnet 29th July no broadband connection,
Steady orange light, sometimes flashing orange, was told it's not syncing?
It took them nearly 5 weeks to actually be able to raise the fault with openreach
Issues with system, possible incorrect BBEU....
Had 2 appointments booked with an engineer last few days,who never attended.either appoinment
Now I've been told there waiting for an update????Huh
Is this typical behaviour from this company now? Been with Plusnet nearly 10 years
5 REPLIES 5
Fixes: 334
Re: 44 days no broadband is this a new record
@Povvercrazy You've been with them 10 years and this is the only fault you have had? Good going.
If you have had the connection for that length of time, 'possible incorrect BBEU' does not sound plausible.
Some areas do seem to suffer from 'non-attendance' by OR, but unfortunately there is little an ISP can do about that, OR are a law unto themselves.
Waiting for an update from OR is what they have to do - see previous comment.
MatthewWheeler
Fixes: 503
Sorry to hear this @Povvercrazy
The case is with our Customer Assist Team who have escalated this with our suppliers to get this sorted
They should be in touch later on today
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Marksfish
Seasoned Pro
Fixes: 4
In response to the title "44 days no broadband is this a new record"
My Dad suffered a 4 month outage of phone and ADSL. Hope you aren't in the same sort of time frame/ priority for Openreach with yours!
Mark
Povvercrazy
I do hope not!
I hope your father was adequately compensated,
The issue I have and it's been the same since day one is they can't raise the fault with openreach!!!!!!
It's laughable
Had to buy a new mobile upgrade to a unlimited date contract and leave it in my loft to get a decent signal strength, just so I have some semblance of internet connection to hotspot from
Openreach should not be insulated from customers like this
Marksfish
Seasoned Pro
Fixes: 4
There was a nice payout at the end of it yes, at £9 per day. Also provided was a mifi type device, which maybe you should push for.
Mark
