403 error https://bt.centercode.com from my Plusnet
outcast
Aspiring Champion
Fixes: 19
Re: 403 error https://bt.centercode.com from my Plusnet
I'm now wondering how reliable that test is anyway ?
I've just seen on the same computer, my "IP Reputation Score" go from 0% to 28%, just by doing a browser page refresh !
Now I'm consistently getting 28% on IPv4, opening a new browser tab and testing it's IPv6 address I get 0%.
pvmb
Champion
Fixes: 17
@Dan_the_Van wrote:
@doug1
I just checked your IP here https://www.ipqualityscore.com/ip-reputation-check/lookup/212.56.108.219
Not good news, it may not just be your IP but others in the same network range
EDIT But https://www.liveipmap.com/  is happy
I'm happy, too!
Check IP Reputation for xx.xxx.xx.x
IP Address xx.xxx.xxx.x
Proxy/VPN Detection Check Clean IP - Not A Proxy/VPN Clean IP Reputation - Not A Proxy or VPN Connection
This IP address is NOT a Proxy or VPN connection. That is good news for your IP reputation.
IP Reputation Score 0% - Clean IP
Blacklist Checks IP blacklist check passed, this IP address was not detected on popular blacklists
Country GB GB
CIDR IP Address Subnet xx.xxx.xx.x
doug1
Fixes: 4
Hi
I did a search for web proxy on bing and this came up.
https://www.croxyproxy.com/
This can see the BT Trials  website login page!
best regards and many thanks for the help.
doug1
Fixes: 4
WARNING - "Man in the Middle" when I use https://www.croxyproxy.com to get around bt.centercode.com blocking my Plusnet fixed IP address - WARNING
I signed up to be a trialist for BT products.
When I access https://bt.centercode.com from my Plusnet Fixed IP address "<redacted> | <redacted>.plus.com | " I get a 403 Forbidden error.
The certificate is Common Name (CN) *.centercode.com
So I decided to google a web proxy, and I tried this:
This can see bt.centercode.com
However although the padlock is locked, the certificate is:-
Common Name (CN) prt.cpprx.info
So I have a "man in the middle" which could read my personal details, like my address and information on bt.centercode.com.
The connectionn is secure to croxyproxy, plaintext across the proxy, and secure from croxyproxy to bt.centercode.com.
The proxy started to serve scamware warnings.
I can see the bt.centercode.com from my GiffGaff mobile data.
I used my 1GB per month Giff Gaff mobile data to change my BT Trials password,
Does BT provide a Proxy that would allow me to take part in the trial?
Moderator's note:
Personal information removed from a public forum (to an area that staff can see).
Fixes: 251
@James_B is this one you can pass into the division please?
James_B
Fixes: 19
I'm on it now @Townman 👍
Thanks for the tag.
James
