turn on suggestions
400 errors
- 400 errors
400 errors
400 errors
03-09-2008 2:00 PM
Trying to access webmail through college has been throwing up an error
Using IE7 on Windows XP Professional, is it my computer or a bad link?
Quote Bad Request
Your browser sent a request that this server could not understand.
Reason: You're speaking plain HTTP to an SSL-enabled server port.
Instead use the HTTPS scheme to access this URL, please.
Hint: https://portal.plus.net:443/
Apache/1.3.34 Server at portal.plus.net Port 443
Re: 400 errors
Re: 400 errors
03-09-2008 2:35 PM
The webmail login page is https://webmail.plus.net/src/login.php and works for me, as does the secure portal link in your post. This is with IE7 on XP Home SP3.
Does your college computer allow SSL (https) connections?
David
Re: 400 errors
Re: 400 errors
03-09-2008 3:39 PM
Yep, I click the link on the main page (http://portal.plus.net) for Webmail, it throws up the 400 error, I click the https link and I go through to the webmail system.
