40% speed drop overnight
alphabet73
My connection has been a beautifully stable with the router reporting a downstream sync of around 68Mb but something happened around 10:30 last night when the sync dropped to around 40Mb and it's been sat there ever since.
Before I start down the fault route, what's the current troubleshooting advice in terms of resetting the line sync? I remember back in the day it used to be unplug the router for 10-15 minutes to allow sessions to time out etc., is that still the recommended method?
14 REPLIES 14
Fixes: 383
Re: 40% speed drop overnight
@alphabet73 Did you note any change in the Hub/routers lights at the time? I doubt a resync would solve this.
Fixes: 383
I suspect, from that excerpt, that you had a drop in your xDSL connection.  Thanks for that snippet, but could you export your full error log and attach it to a reply - there may be more information in there that may be of interest?
alphabet73
Fixes: 383
@alphabet73 We actually need your error log - not the data you have supplied.
alphabet73
Doh! That's what I get for trying to multitask...didn't realise I was on the wrong tab when I hit Export!
Try this...
corringham
Seasoned Champion
Fixes: 23
The log appears to show connections on different dates with download at various rates between 80Mbps and 21Mbps, so it may not have been as consistent as you believed.
The current stats (in your first log) show a max data rate of 42.4Mpbs with a 3.3dB noise margin - that suggests your connection is not banded, and that is the max rate attainable currently. You need to report a fault.
alphabet73
Thanks @corringham , I'll get a fault raised.
I'm guessing I must have just timed my speed tests well to see the higher speeds as certainly didn't see the slower ones before today.
Fixes: 383
As I suspected, you had a DSL drop for some reason, and whatever the reason was, the DLM decided your connection needed throttling to maintain stability. I suggest you call in and ask Support to reset your line - it should reset to your 'normal' speed.
As a point of interest, your DS SNR is a little low for your attenuation, which may account for the severe drop.
Fixes: 383
Good spot, @corringham - the OP certainly has a problem.
Anunnaki
corringham
Seasoned Champion
Fixes: 23
@jab1 wrote:
... the DLM decided your connection needed throttling to maintain stability.
but I believe in the case where the DLM reduces the speed to improve stability there would be a max speed well above the actual rate, and a large DS SNR.
From the logs this doesn't look like a particularly unstable connection that would be throttled.
@alphabet73
I take it you're running a couple of servers  on 192.168.5.254 as there are many external connections on port 80 and 443, 192.168.5.60 external connections on port 4040 and 32400.
Fixes: 383
All those earlier drops, which I admit I missed as I didn't do my usual fault isolation, would have caused the last apparent reduction.
alphabet73
And problem solved...seems there was an 'event' which may have impacted multiple users (not sure what the event was as support had no additional info).
One remote reboot of the router later and sync speeds are as they were before whatever caused last nights blip.
Thanks for everyones input.
