3 months in and fibre speeds gone from 77mb to sub 20mb
- Re: 3 months in and fibre speeds gone from 77mb to...
01-07-2013 12:28 PM
Here we go again already had several BTW visits but my sync drops more than a whores draws my speeds have gone from 77mb to less that my old broadband speeds, my profile is saying 20mb where it used to say 77mb. I believe this is not Plusnets fault as i have always had an issue with sync drops that 2 BTW visits have not fixed.
i can ring my house number and break the sync then it resets and sits stable for a couple of hours and then it goes again, i have not been keeping track of my speeds recently unlike when i first got fibre and i all seem to do was run speedtests, but the speeds are now so low that i may as well go back to copper BB.
Please could someone post my radius graph, also i have logged a ticket 71402812.
Please help me get my speed back as once you have tasted 77mb you dont want anything else.
Message 1 of 7
(2,275 Views)
6 REPLIES 6
Re: 3 months in and fibre speeds gone from 77mb to sub 20mb
01-07-2013 12:59 PM
Happened to me too.
Message 2 of 7
(827 Views)
01-07-2013 1:23 PM
There should be no interaction between the phone and broadband,The fact that there is suggests you have a line fault, and the number of disconnects will have most probably caused DLM to lower the speed and increase latency, The fault will need fixing ,before dlm is reset , Any audible noises on the line when you do a quiet test 17070 option 2 using a corded phone plugged into the test socket, which is behind both faceplate's with only phone connected,? if you can hear crackling or other odd noises ,you can report this as a PTSN voice Fault, to who ever you pay line rental too,
If no noises can plusnet not run the newer openreach CIDT test http://www.openreach.co.uk/orpg/home/products/llu/cidt/cidt.do , which are supposed to detect HR type faults
Message 3 of 7
(827 Views)
01-07-2013 4:25 PM
As requested, a visual radius:
<img src="http://community.plus.net/visualradius/generated/image13726922526382.png"/>
Our faults team will take a look over your connection to see what's going on and provide an update on the ticket you mentioned.
Message 4 of 7
(827 Views)
03-07-2013 10:59 AM
Hi Guys any update on this, i have looked at the ticket but its all greek to me, still i suppose 15mb out of 77mb is better than nothing eh? .
Just want to say that i have had this fault since before i joined you guys, and have tried all the possibilites regarding 17070, test sockets, different routers etc.
i only have 1 master socket no phone plugged in.
even tried looking down the back of the sofa for the missing 50mb
Please help me!!!!!
Dro
Please help me!!!!!
Dro
Message 5 of 7
(827 Views)
03-07-2013 1:05 PM
We've raised a fault with our suppliers regarding your connection, our faults team are following this up and will be in-touch with our findings.
Message 6 of 7
(827 Views)
03-07-2013 3:52 PM
thanks Chris
Message 7 of 7
(827 Views)
