3 meg instead of 6
MickHowes1
3 meg instead of 6
cant even watch a twitch stream................ http://www.speedtest.net/result/3153065064.png
Shud be on between 6-7 sort it out. and try lower my ping pleasdeeeeee
1 REPLY
Fixes: 165
Re: 3 meg instead of 6
If you're still seeing problems once the Max Premium order completes, then I'd suggest running through the faults checker at https://faults.plus.net
 Chris Parr
 Plusnet Staff
