3 Months tomorrow
- Re: 3 Months tomorrow
3 Months tomorrow
21-03-2008 9:52 PM
However after my initial period I was getting a BT profile Of I believe 6000 kbps untill I had a fault of which I must admit was my doing .
It was quickly sorted and after a period of stability Bt raised my profile back up , but only to 5000 kbps . My line has remained stable ever since with speeds normally at about 4400-4500kbps . I am unable to do a BT test at the moment as their line is busy,
but below are some My Broadband results .I must stress that I am NOT complaining
but I am supposed to be able to get upto 6.5mps in my area according to some website ( I cannot remember which).
I was wondering why BT had not put my profile back to 6000kbps
Date Download Speed Upload Speed
Today 21:30 4452 kbps (557kB/s) 379 kbps (47.4kB/s) Share
Mar 10, 23:41 4699 kbps (587kB/s) 379 kbps (47.4kB/s) Share
Mar 10, 23:38 4707 kbps (588kB/s) 378 kbps (47.3kB/s) Share
Mar 5, 23:53 4741 kbps (593kB/s) 377 kbps (47.1kB/s) Share
21-03-2008 9:56 PM
To comment on your profile the router stats (SNR margin etc.) would be useful.
21-03-2008 9:57 PM
This would give exactly the results you are seeing.
If you do a manual resynch and check the downstream noise margin immediately (or look in the router log as it may give that information) this should tell you.
If I am correct it should sort itself out in theory but in practice often doesn't so the only way is to raise a ticket asking for the default noise margin to be lowered.
You may need to be patient because BT seem to be reluctant to do it.
21-03-2008 10:04 PM
P.s My speed has remained stable for about 2 months now
21-03-2008 10:24 PM
21-03-2008 10:31 PM
System Up Time 29:00:38:17
ADSL Speed (DS/US) 6016/448 Kbps
LAN IP Address 192.168.1.1
Default Gateway 195.166.128.101
Primary DNS Server 212.159.6.10
Secondary DNS Server 212.159.6.9
Firmware Version 3.03c
Boot Loader Version 1.0.37-21.6.11
ADSL Driver Version A2pB018c1.d16d
Ethernet MAC Address 00:16:E3:4E:FD:0A
21-03-2008 10:36 PM
21-03-2008 10:37 PM
21-03-2008 10:40 PM
21-03-2008 10:44 PM
21-03-2008 10:48 PM
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 23:09:27:27
Line Coding Trellis Off Line Up Count 3
Statistics Downstream Upstream
Line Rate 6016 Kbps 448 Kbps
Noise Margin 14.9 dB 22.0 dB
Line Attenuation 39.0 dB 22.0 dB
Output Power 19.8 dBm 11.9 dBm
21-03-2008 10:50 PM
14.9dB is quite high.
On the other hand attenuation at 39dB implies you're about 3Km from the exchange in which case you could maybe get a little more speed, but not much.
21-03-2008 10:52 PM
21-03-2008 10:55 PM
Is that good or bad ?
21-03-2008 11:01 PM
